Need help finding the right tools for a 3 finger cigar case
Forum topic by flwoodie posted 06-24-2013 05:58 PM 850 views 0 times favorited 4 replies Add to Favorites Watch
View flwoodie's profile
26 posts in 1761 days
06-24-2013 05:58 PM
Topic tags/keywords: cigar case spanish cedar forstner
I’m trying to build a 3 finger cigar case from spanish cedar similar to the once pictured below. I am using a forstner bit in my drill press to drill 3×3/4” inch holes into a block of spanish cedar.
Question 1: The forstner bits are not long enough to drill down approx. 6”, so I guess I need to use an extender. Any tips of a good, stable option?
Question 2: Once the holes are drilled, I need to sand the inside smooth. Any ideas on an easy way to do this? I was hoping for a little cylinder I could put in my drill press, but maybe that would just be too easy.
Any help would be greatly appreciated
View crank49's profile
4030 posts in 2901 days
#1 posted 06-24-2013 09:04 PM
Split the end of a dowel that’s about 2/3 the size of the hole and insert a strip of emery cloth (or any cloth backed sand paper). Chuck up the dowel and sand away.
View jumbojack's profile
1673 posts in 2554 days
#2 posted 06-24-2013 09:15 PM
Split your entire blank and use a router. Glue the halves back together. Easy.
#3 posted 06-25-2013 11:30 AM
I don’t want to split the blank, the dowel idea sounds easy enough. Thanks for the help
View Buckethead's profile
3194 posts in 1799 days
#4 posted 06-25-2013 11:44 AM
Brilliant idea crank!
I’m sure it’s been around, but I was trying to think of something the other day and came up empty. Next time, I’ll have a ready solution.
-- Support woodworking hand models. Buy me a sawstop.
