Air filtration
« back to Scrollsawing forum
Forum topic by Dan58 posted 06-24-2013 07:42 AM 888 views 0 times favorited 3 replies Add to Favorites Watch
View Dan58's profile
Dan58
7 posts in 1818 days
06-24-2013 07:42 AM
I will be scroll sawing in my basement as I have no other place to do it I want to get an air filtration system and I was looking at the small shop vac unit I wouldn’t mind getting a large hanging unit but filters are so expensive and they’re noisy any suggestions I know ideally I should use the larger hanging system but I thought just for the scroll saw dust the small shop back portable unit would be big enough Thanks
-- Dan 58 Nebraska
3 replies so far
View oldwormy's profile
oldwormy
16 posts in 1888 days
#1 posted 06-24-2013 01:12 PM
Get a box fan and tape furnace filters to the front and back. Shop vacs are not designed to run continously and are too noisy. I also use a dust collector with the duct close to the saw.
-- AlW
View MT_Stringer's profile
MT_Stringer
3168 posts in 3228 days
#2 posted 06-24-2013 04:24 PM
I use a box fan also – 20 incher. Amazing to see the filter as it gathers up the dust.
View Redoak49's profile
Redoak49
3242 posts in 1986 days
#3 posted 06-28-2013 09:57 PM
I agree that MOST shop vacs are not made to run continuously. However, the more expensive ones are able to to that. I almost hate to mention it but I believe that both Fein and Festool are designed that way and are also capable of being HEPA vacs. The issue being that the prices start at $290-$350.
I do a lot of scroll saw work and think it is best to collect the dust as close to the source as possible. The dust from a scroll saw is usually very fine and can hang in the air a long time. Also, if you are using some of the exotic woods, these can pose a danger. Using a box fan may work to some degree but catching the dust as it comes off the blade is better.
I have a Hegner that I got used and built a collection system using some short pieces of PVC and fittings along with some of the loc-line flexible hose and fittings. I collect dust both above the table and below the table. I get no dust on the floor or anywhere else.
I got the loc-line pieces from Modular Hose and got a good price and quick delivery.
