HELP with lift mechanism on Jet table saw
Forum topic by flwoodhacker posted 06-23-2013 12:40 PM 8083 views 0 times favorited 14 replies Add to Favorites Watch
View flwoodhacker's profile
flwoodhacker
58 posts in 2920 days
06-23-2013 12:40 PM
Topic tags/keywords: tablesaw
I have a Jet JWSS-10LFR table saw. The lift mechanism stopped working by not allowing the blade to be raised or lowered. Opening up the saw from the front I saw that a woodchip had jammed itself into the lift trunnion. Parts from the crank to the bracket were removed to access the chip.
However, one that was removed and reassembled the crank “system” flops all over. The “pointer” that marks the blade tilt will not hold it’s position. I noticed that the pressure block rotates as well when I turn the handle. A visit to the local woodworking Jet dealer proved worthless. I contacted Jet directly and they never heard of such an issue. Customer service was going to call me back but never did and getting through to them is pretty difficult.
Pictures and a video are attached to hopefully display the issue.
Here is a video
Video
Any guidance is appreciated.
14 replies so far
View mikepdarr's profile
mikepdarr
19 posts in 2848 days
#1 posted 06-23-2013 03:09 PM
Maybe you would get more replies if you edited out the Michael Jackson tune.
View johnstoneb's profile (online now)
johnstoneb
2911 posts in 2167 days
#2 posted 06-23-2013 03:42 PM
I don’t know anything about Jet table saws but looking at the attached parts breakdown. I would guess that at least one or more of the parts on the elevation shaft behind the wheel are not installed or indexed properly.
http://www.ereplacementparts.com/jet-jwss10lfr-708770-lefttilting-1034-supersaw-parts-c-32652_32759_37588.html
-- Bruce, Boise, ID
View Pfadfinder's profile
Pfadfinder
3 posts in 1774 days
#3 posted 07-13-2013 02:31 AM
I have the same saw and just replaced the timing belt. You must tighten the 1 inch nut on the back of the shaft. Then use 4 mm hex wrench to set red pointer.
View redSLED's profile
redSLED
790 posts in 1887 days
#4 posted 07-13-2013 02:40 AM
If the issue is permanent, I would like to acquire your table saw’s hand wheel for free, to attach to my face vise instead of the dowel handle. Thanks in advance.
Otherwise, you must have a simple mechanical failure which requires a partial tear-down to rectify I would think. Forget Jet customer service – it’s not like they’ll fix your table saw for you over the phone. Also, it looks like you got your answer above from Pfadfinder.
View Straightbowed's profile
Straightbowed
717 posts in 2292 days
#5 posted 07-13-2013 03:10 AM
ching ching chang ching
-- Stevo, work in tha city woodshop in the country
Pfadfinder
#6 posted 07-13-2013 05:31 PM
Did that fix your problem? Let me know as I can send you a picture which should help.
View davie's profile
davie
2 posts in 4040 days
#7 posted 10-28-2014 05:03 PM
- Pfadfinder
davie
#8 posted 10-28-2014 05:06 PM
- Pfadfinder Hey Pathfinder – I’ve replaced my timing belt…sort of. Couldn’t get anything from Jet. Went to a belt-hose shop and got a “near fit.” Not real good. Where did you get your replacement belt? Thanks. Agree with others…Jet isn’t much help with anything any more.
Pfadfinder
#9 posted 10-28-2014 06:13 PM
From Jet. The company is the same one that makes Powermatic. Walter Meier Mfg.
View Muggaseckele's profile
Muggaseckele
1 post in 948 days
#10 posted 10-17-2015 03:22 AM
Just wondering if the OP ever figured out the issue with the lift mechanism. I just bought the same saw, and it has the same issue. I took the whole lifting shaft off, and found that a washer behind the belt tightening bolt was missing. Not sure if that will fix it. Let me know if you were able to fix yours.
-- Muggaseckele (Swabian for the smallest amount one can shave of a board)
View Gail's profile
Gail
44 posts in 3952 days
#11 posted 11-29-2015 09:48 PM
I just took my saw apart thinking it was the timing belt that was broken, it wasn’t. When I turn the wheel the blade will not move (nor the gears that hold the belt) – after putting it all back together, I see a note here about tightening the 1” nut on the back of the assembly. Any other suggestions before I take it apart again?
thanks all!
-- Gail, White Wood Kitchens
View Laughran's profile
Laughran
72 posts in 1923 days
#12 posted 12-01-2015 12:33 PM
Gail, the belt could just need tightening or the belt is worn out.
Look to see if the belt is starting to shred or come apart.
I just replaced mine again and found a replacement belt on polybelt.com,
Item no B369-3M-10BNG Rubber timing belt, 123 tooth
They have a $10 minimum order so I ordered 4 and with shipping was just over $18
-- David
View knotscott's profile
knotscott
8008 posts in 3370 days
#13 posted 12-01-2015 02:21 PM
That’s the original Jet Supersaw, and was known to have issues with the “timing belt” height adjustment design. You may need to replace the lift belt, but I’d contact Jet first to see if they’ll offer any insights.
View Gail's profile
Gail
#14 posted 12-04-2015 11:35 AM
Thanks all, will have to order the belt and then try again.
I have done it twice already, I think if I fix it this time, I will fix and put out for sale. Boo.
