band saw or scroll saw
Forum topic by albut posted 401 days ago 276 views 0 times favorited 8 replies Add to Favorites Watch
Rockler
View albut's profile
albut
48 posts in 592 days
401 days ago
Topic tags/keywords: question
what kind of saw must buy scroll saw or band saw?
Dick, & Barb Cain
7050 posts in 1199 days
401 days ago
It depends on what you’ll be using it for.
A scroll saw is only good for thinner materials.
View GMman 's profile
GMman
1370 posts in 597 days
401 days ago
A scroll saw is a craft tool and a band saw is a woodworking tool, but don’t do like I did I purchased a small cheap ban saw and it is no good it is sitting in the corner collecting dust.
-- --<<<<<< I will not stop until I get it right. >>>>>>--
View Loren's profile
347 posts in 548 days
401 days ago
A good scroll saw is a pretty versatile tool. Cheap ones aren’t.
You can cut brass and other metals with a nice scroller.
A band saw is more versatile for furnituremaking – the one
machine I wouldn’t want to build furniture without.
-- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html
View kolwdwrkr's profile
kolwdwrkr
2262 posts in 490 days
401 days ago
well you can’t do scroll saw work on a bandsaw because you can’t remove the blade and put it through your piece at a good starting point. On the other hand you can’t resaw your own veneer with a scroll saw. So, buy both ;-)
View DaveH's profile
DaveH
372 posts in 678 days
401 days ago
I would get a band saw first unless you are heavy into scroll work that requires a starting point inside the work piece. You can make some pretty tight curves with a band saw with an 1/8” blade. You can buy a decent used 14” bandsaw in the $200 to $300 range.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
albut
401 days ago
tanks all for your help i think will buy a band saw
View SCOTSMAN's profile
SCOTSMAN
2244 posts in 485 days
401 days ago
A scroll saw is a bit of a luxury and all the cuts exept internal cuts can sometimes be better done with a thin blade on a bandsaw.I would reccomend a bandsaW every time over a scrollsaw although I have both, the scroll saw gets very infrequently used .However naturally if you like scrollsaw work a lot and hope to do this kind of work specially then get the scrollsaw get a good one I spent a bit of money and bought a good top of the range American Delta and I really like it,good luck Alistair
View woodup's profile
woodup
145 posts in 843 days
401 days ago
I started with a scroll saw, as my initial projects were focused on scroll work and making inside cuts on particularly thin boards ( 1/8” to 1 1/2”). I later purchased a ‘craft’ bandsaw that could ‘potentially’ cut up to 5” thick piece of wood. Potentially, because practically it didn’t cut it. I have been fortunate to get a large band saw and a woodslicer blade, and I’m sold on the idea of the big band saw. Good luck on your tool accrual journey.
-- Michael, Fort Worth, TX. "I wood if I could!"
