Forum topic by felkadelic | posted 06-21-2013 02:53 PM | 3031 views | 0 times favorited | 11 replies | ![]() |
I just became aware of this product, a spray-on water repelling barrier. Would this be appropriate on, say, a hand plane sole? I’m not sure if it’s only usable on galvanized metal, or if cast iron would be okay as well. There are of course concerns with the barrier transferring to a workpiece, messing up a future finish. Anyone tried it? |
11 replies so far
#1 posted 06-21-2013 03:02 PM |
Why, if I may ask, would you want to use that when Johnsons Paste Wax is cheaper, would probably last just as long when sliding across a wood surface and is easy to apply as needed? I have a feeling the Rustoleum is going to add a significant layer of gunk to the bottom of any plane. -- Improvise.... Adapt...... Overcome! |
#2 posted 06-21-2013 03:03 PM |
Just floating the idea out there… |
#3 posted 06-22-2013 01:18 PM |
+1on da wax. -- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA. |
#4 posted 06-22-2013 01:39 PM |
Buy some and try it out only way to find out. While the cheapest and already known product is at times the still the best solution the scientist laughs at the times this has been said over the years…..I mean a cave worked just fine and was cheaper but…. Now I would test it out on stuff you don’t care about first, cheap chisel for instance. Will the product transfer to the wood piece and hurt glue up, staining, paint, etc… how well is the adhesion and abrasive resitence, etc…... |
#5 posted 06-22-2013 03:51 PM |
Based on the video, I wonder why food manufacturers don’t coat the insides of syrup, ketchup and chocolate sauce bottles with it. -- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln |
#6 posted 06-26-2013 09:39 PM |
I would be nervous about using it on the soles. Might be worth a try on parts that don’t touch wood, such as the inside parts of the plane. I gave up on using Johnson’s paste wax because it contains silicone. I’ve never had a problem with it affecting finish, but I don’t want to start now. I have a bar of bee’s wax that does an amazing job. Another guy I know uses ski wax on his soles. You should probably stay away from the klister wax unless it is really wet or icy. In that case, you really shouldn’t be planing wood until conditions improve. -- Tony - http://ravensedgetoolworks.com |
#7 posted 06-27-2013 01:29 AM |
Tony, where did you hear that about JPW? The MSDS for it does not list silicone, which should be pretty definitive. They can get in legal trouble if they lie there. |
#8 posted 06-27-2013 01:53 AM |
If you look at the MSDS you’ll see why food manufacturer’s don’t use it. EFFECTS OF OVEREXPOSURE – CHRONIC HAZARDS: May cause central nervous system disorder (e.g., narcosis involving a -- Bruce, Boise, ID |
#9 posted 06-27-2013 02:23 AM |
#10 posted 06-27-2013 03:52 AM |
I am a product reviewer for a large retail chain. I recently got to review this. 1 – It’s awesome stuff. Works way better than advertised HOWEVER – I found the perfect use for it. Parallel clamps! Anyone who has spent a weekend scraping glue off of their parallel clamp bars will really appreciate this stuff |
#11 posted 06-27-2013 08:16 PM |
There is nothing food safe about this product. It does not last indefinitely and wears off through abrasion. Why are you getting water on you plane? Stop doing that. The product itself is fantastic. It will do what it says. I’ve sprayed it on clothing, shoes, my DISH dish (no more sticking bird poop). I wouldn’t put it anywhere near my woodworking. Just like I wouldn’t put water anywhere near my tools. -- Sam Hamory - The project is never finished until its "Finished"! |
Forum | Topics |
Woodworking Skill Share
12032 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5411 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4758 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
