Lubricating moving wood parts
Forum topic by Denco posted 06-21-2013 02:53 PM 3591 views 0 times favorited 6 replies Add to Favorites Watch
View Denco's profile
Denco
39 posts in 2057 days
06-21-2013 02:53 PM
Topic tags/keywords: router lift lube jig
I built the router lift in the link below. It came out great, I’m very happy with it. It’s an excellent design. Kudos to the designer. The lift was constructed with plywood purchased at a big orange store. In the instructions, the designer noted to lube the carriage tracks with petroleum jelly. Although I have no reason to doubt him, I was just wondering if there were good, alternative lube options available. I was thinking the petroleum jelly might attract saw dust (but I have no experience with it). I’m more interested in lube I can pick up at the big box stores instead of ordering online for this project. Any ideas? Very grateful in advance for any wisdom shared.
http://www.ibuildit.ca/Workshop%20Projects/router-lift-1.html
-- Cut wood or cut weeds today.....well, 6ft weeds can go another week.
View Gene Howe's profile
Gene Howe
11147 posts in 3666 days
#1 posted 06-21-2013 03:10 PM
My favorites are Paraffin, or a toilet wax ring. Both cheap and, depending on the application, do the job well.
The paraffin would probably attract less saw dust.
Both are available at an ACE store, at least the one close to me.
I would think that either would be longer lasting in use than petroleum jelly.
Another thought….might not be practical for your use, though….I make band saw guides from hard wood and soak them for a few days in used motor oil. They stay lubed for ever.
404 - Not Found
2544 posts in 3207 days
#2 posted 06-21-2013 03:37 PM
There’s a product called Waxilit, sold as an anti seize compound for planer beds, that is imo, the best wood lubricant available. I believe it is parafin based.
117417 posts in 3814 days
#3 posted 06-21-2013 03:42 PM
I’ve used the same things Gene has.
View gfadvm's profile
gfadvm
14940 posts in 2927 days
#4 posted 06-22-2013 01:23 AM
I just use MinWax Paste wax on my drawer slides,etc and it seems to work well and lasts a long time.
View mvilares's profile
mvilares
11 posts in 2037 days
#5 posted 06-22-2013 01:31 AM
If you are referring to metal parts, I use T9 Boeshield or a dry PTFE (teflon) lubricant that you can find at any big box store. For wood you could also use beeswax as an alternative to the others already mentioned.
View juniorjock's profile
juniorjock
1930 posts in 4003 days
#6 posted 06-22-2013 01:43 AM
Doesn’t get any slicker than Slip-It. Works on anything.
