| Forum topic by snowdog | posted 398 days ago | 260 views | 0 times favorited | 12 replies | ![]() |
398 days ago |
Topic tags/keywords: winterize So it is that time again and I am getting ready to winterize the many out door work horses that consume gas. My question is, what is your preferred way of winterizing? Here is what I think: Added stabilizer In the past: added stabilizer shut off the gas line valves and ran the carburetor dry Took out the plugs sprays a little oil in the cylinder put plug back Seems like a waste of time -- "so much to learn and so little time".. |
398 days ago |
I don’t have anything I winterize since I rely on most of it all year long. The two things I use sparingly throughout the year: the generator and pressure washer I just shut off the glas using the in-line valve and run dry. All I have ever done to them. The generator starts right up every time, even in the winter. I have never tried to start the pressure washer in the winter but it always starts right up in the spring, heck I think the gas in it is from 2003 or so since I use it so sparingly. I have never used stabilizer, ever. When I summer-ize the snowmobile I don’t do anything there either, that is a 2-cycle engine so I just shut it off and then shut off the gas valve, don’t run it dry or anything. After it has cooled I take out the spark plug and after letting it air out for a day I replace the plug so nothing tries to make a home in the engine. Weedwackers and lawn mowers I just siphon out the fuel and run dry. Again, I think my supply of 2-cycle fuel mix is about 5 years old and everything still runs great on it, never added a lick of stabilizer. -- Rich, WNY, www.nyrockingchairs.com |
398 days ago |
Interesting topic. Bob -- A mind, like a home, is furnished by its owner |
398 days ago |
I don’t winterize my RV or my generator – if we lose power, we move into the RV while the generator keeps the fish tanks warm. I do run them for about an hour a month however. -- Derek, Bremerton WA -- |
398 days ago |
I just don’t summer-ize So Much easier. I keep everything in running order all year. You neverr know what will come up. -- The only easy wood project is a fire |
398 days ago |
I lived in Iowa for my entire life before moving here in ‘05. It can get below zero there for days on end. I never did anything to my gas powered stuff. The worst that ever happened was to buy a new spark plug in the spring. bbqKing. -- bbqKing, Lawrenceville |
398 days ago |
I just add Stablil, turn off the fuel valve, run until it quits, and put the rest of the fuel in the snowblower. I also change my oil every fall, using synthetic, and bring the batteries into the basement. I ALWAYS check the belts on the snowblower, as it’s much easier to change a belt in October than when the driveway needs “doin’”. No issues here in CT… -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
397 days ago |
I add Marvel Mystery Oil to the tank let run for about 60 seconds, das ist alles! Spring, new oil (for the 4 cycles), spark plugs, and whatever else needs replacing (pull cords anyone) about every other year. What I am looking for are suggestions for maintaining the battery in my riding lawn morning. It likes to die and need replacing frequently at least in my book. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
397 days ago |
Come down under Snowdog. The weather is warming up day by day. -- Grumpy - "Always look on the bright side of life"- Monty Python |
397 days ago |
Does moving them out of the way count as winterizing? I suppose I really should do something other than just stop using them. -- ...it's rennovation time!!! |
396 days ago |
I forgot to include the battery. Last year I ran a trickle charger to a few of the batters that were outside. I think this year I may take them out and bring them into the shop. In my neck of the woods it gets below 0 (Fahrenheit) on many days. I have also hear that you should never let your batters sit on the concrete so I’;; place it on a board somewhere. -- "so much to learn and so little time".. |
396 days ago |
I’m with Bob #2…, another task for this afternoon. |
396 days ago |
…and then it’s time for paste wax on the saw tables and jointer. Ugh. As I have aged I find nothing redeemable about winter. -- "Bordnerizing" perfectly good lumber for over a decade. |
| Forum | Topics |
Woodworking Skill Share
2917 |
3944 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
