Help Identifying Grandfather's Old Tools
« back to Hand Tools forum
Forum topic by Culbertson posted 06-20-2013 08:49 AM 2177 views 0 times favorited 17 replies Add to Favorites Watch
View Culbertson's profile
Culbertson
7 posts in 1799 days
06-20-2013 08:49 AM
Topic tags/keywords: vintage antique old new handtools
Hello All! Need help in Identifying some old woodworking tools of my grandfather’s. I’d like to know what each tool is for and the name. How could I clean them up, especially the rusted blades. What type of wood are they made of? Were they made in the U.S.? Are they worth much? Thanks!!
http://i1272.photobucket.com/albums/y400/T_Culbertson/09-IMG_7824_zps55d3caf3.jpg!
Thanks!!!
-- Tracy, Bedford Co. Virginia
17 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2035 days
#1 posted 06-20-2013 12:58 PM
I’ll give it a shot. Maybe someone else will chime in with a second opinion.
1. rebate plane body, no wedge or iron – no value.
2. rebate plane in poor shape with rusty iron and worm holes on body. #105 stamp means it was probably one of the bigger more common makers like Auburn or Ohio Tool Co (might be a makers mark under that grime) Might get $3 or $4 on a good day, less if someone had to pay postage.
3. incomplete Stanley plane missing cutter. Without measurements I don’t kow the model but it looks to be a #5. Also has no chipbreaker and levercap. If body isn’t cracked it might get $7 to $10 for someone who needs the remaining parts or has a shoebox full of all the missing parts. If it is a #5, then even if it was complete it is the most common plane and stanley made millions so value wouldn’t go too high unless it was minty in the box.
4. incomplete horn plane (smoothing plane) with rusty iron and no wedge. They’re very common, a lot are made in scandinavia. Antonberg is collectible, but not really in that condition. Wood looks like it started to rot. It could sell for $10-15 to someone who knows Antonberg and has the time to repair it.
5. Another horn plane with no wedge and the wrong iron. No value in the wood, might get $2 for the iron if it’s straight with no rust or $5 for the whole thing if you can convince someone they can fix it up.
6.7. Two monkey wrenches one with wood handle (broken and heavy rust) and one all-metal (more modern). Ebay is awash in unsold monkey wrenches by common makers in that condition. At the flea market they sell for 1-2 bucks each.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
Smitty_Cabinetshop
15349 posts in 2615 days
#2 posted 06-20-2013 01:18 PM
First picture.
Smitty_Cabinetshop
#3 posted 06-20-2013 01:21 PM
Later type Stanley jack, based on bottle-shape to the frog and the raised ring. T16+. Can be a good user, tote looks to be intact, but like Joes says, there are parts missing (iron, chipbreaker, lever cap) and that’s a bummer.
Culbertson
#4 posted 06-20-2013 01:37 PM
Thank you JustJoe and Smitty. It’s really a shame that these guys are in such bad shape. Lord knows how long they’ve been sitting in the cellar. My grandfather passed away over 28 years ago! So, I guess these have more sentimental value than anything else. Could you maybe post a picture of a complete plane and point out the parts that I am missing on mine (iron, chipbreaker, lever cap) so maybe if I come across these things I could try to fix it up? What’s a good way to remove the rust and grime on the blades and metal pieces without compromising any of the maker marks?
Culbertson
#5 posted 06-20-2013 01:41 PM
Oh, and the Stanley is a #5. And, do any of you know what the P. Stogren means on the rebate plane? Or the A.C.S. on the horn plane? Is 1908 a date?
Smitty_Cabinetshop
#6 posted 06-20-2013 02:23 PM
Probably hundreds of No. 5 jacks on ebay, Tracy. Search “Stanley 5 plane” and you’ll see. Look for lever caps that have STANLEY within an orange-filled rectangle and kidney-shaped hole for the cap screw, and that’s your plane. There will also be the raised ring under the knob.
View Makarov's profile
Makarov
102 posts in 1802 days
#7 posted 06-20-2013 02:46 PM
Take the tools and give them a good bath with simple green and a toothbrush, get the grime off. Then give the wood a rubbing of boiled linseed oil and the metal a little WD40 and you can display them. the #5 may be worth fixing, better pictures of it after you clean the grime off will help decide.
-- "Complexity is easy; Simplicity is difficult." Georgy Shragin Designer of ppsh41 sub machine gun
10383 posts in 3644 days
#8 posted 06-20-2013 03:54 PM
Maybe worth $80-$100 for the lot, optimistically.
The horn planes may be slightly collectible, but
they are not in good looking condition so it’s hard
to say if anyone will want them very much.
Eric Anton Berg chisels are very fine, but I don’t
know if the horn planes have the same cachet.
Check ebay completed auctions for what they sell for.
Culbertson
#9 posted 06-20-2013 05:35 PM
Thank you so much! I’m going to try to clean them up within the next couple days and post more pic.s! I appreciate the advice :)
View Woodknack's profile
Woodknack
11616 posts in 2377 days
#10 posted 06-20-2013 07:39 PM
Probably cheaper to buy a complete #5 and take parts off than buying just the parts you need.
View redSLED's profile
redSLED
790 posts in 1889 days
#11 posted 06-20-2013 10:32 PM
First picture, 2nd item – that is a Viking overhead half-apple slicer. When in ‘exotic lands’ the Vikings would cut their apple (or similar sized fruit) in half with their battle axe, then insert the half into that gizmo and manually shoot the fruit slices, in an overhead position, directly into their mouths – thereby savouring each slice to its maximum. The blade shown appears to be attached incorrectly.
Culbertson
#12 posted 06-21-2013 01:49 AM
Are you serious redSLED? That sounds crazy! Or are you joking?
I just finished cleaning and I will post new pictures soon.
JustJoe
#13 posted 06-21-2013 02:12 AM
Thanks redSLED! Once google indexes that post we’re going to see a flood of $4 worm eaten rebate planes being listed on fleabay as “Rare Viking Apple Slicers” with asking prices of $500 on up. And you know it only takes one gullible buyer to bite and everyone else will jump on the bandwagon. I’ve got a half dozen beaters sitting on the shelf – Hopefully I can time the market good enough to re-retire to someplace a bit nicer than this desert wasteland…
View Greg In Maryland's profile
Greg In Maryland
553 posts in 2994 days
#14 posted 06-21-2013 03:18 AM
The Norse were not the only ones to come up with the half-apple slicer. The Maori in Australia and New Zealand came up with it also. Naturally, they called it the “downunder half-apple slicer” and they would shoot the fruit slices underhanded to their mouths.
Woodknack
#15 posted 06-21-2013 05:45 AM
What?? Everybody knows that Native Americans, who invented the apple in 865 A.D., brought apple slicing technology to Europe during their frequent plunders of the coastline.
