Cupping and twisting in very thin peices
Forum topic by Cygnwulf posted 06-20-2013 01:14 AM 1183 views 0 times favorited 3 replies Add to Favorites Watch
View Cygnwulf's profile
Cygnwulf
30 posts in 2031 days
06-20-2013 01:14 AM
Topic tags/keywords: veneer twist cupping movement
Ok, so I posted a project a little while back where I was experimenting with thin wood bookmarks made by doing a small marquetry piece and then applying it to another piece of veneer as a substrate. Unfortunately so far the experiment has not been a total success. I’m happy with the strength and durability of them, and my wife has been very happy with her’s, with one caveat: it twisted.
Had it cupped it wouldn’t be as noticeable, but twisted takes a little something away from it.
Now, I know the wood moves, but I was hoping to find some way to avoid the worst of it. So far, the only test pieces that haven’t twisted were the ones that had a good amount of crossing grain, the ones where the grain in both layers mostly runs the same way are the ones that are twisting. the cross grain ones still cup a bit but it’s not horrible.
A test peice I did that deliberatly crossed the grain from the front and back cupped some but did so evenly.
I did one test that had 3 layers, with the core going across the others, and this one stayed very flat.
I realize that I’m not going to eliminate the wood movement but I would like to minimize or control it.
I’m wondering if this is a project that I’m just going to have to give up on, or if anyone might have any suggestions on other solutions I might try to either minimize the twist or at least even it throughout the finished piece? I am using mostly either very straight grained veneer or some highly figured ones.
-- Stephen H -- If it ain't broke, it probalby still needs fixing....
3 replies so far
View bondogaposis's profile
bondogaposis
4611 posts in 2258 days
#1 posted 06-20-2013 04:07 AM
That’s your answer right there. Laminations must be balanced top, bottom and middle.
-- Bondo Gaposis
View Rick_M's profile (online now)
Rick_M
11121 posts in 2287 days
#2 posted 06-20-2013 07:19 AM
Yep, rule of thumb with lamination is that whatever you do to the top, you do to the bottom.
-- http://thewoodknack.blogspot.com/
View Nomad62's profile
Nomad62
726 posts in 2865 days
#3 posted 06-20-2013 08:24 PM
The vast majority of wood movement is from moisture movement; while you didn’t say which glue you used, make sure it is one that is not water based and you may get better results.
