Ridgid Bandsaw Motor Upgrade
Forum topic by Hermando posted 06-19-2013 07:12 PM 1459 views 1 time favorited 6 replies Add to Favorites Watch
View Hermando's profile
Hermando
75 posts in 2766 days
06-19-2013 07:12 PM
Hello Jocks,
I am looking for some advice on upgrading the the 3/4hp induction motor on my 14” Ridgid band saw. The current motor is 3/4 hp and was wondering if there is an advantage to using a 1 1/2 induction belt drive motor. Is it possible that this would be a clean swap or is this overkill.
Thanks, H.
View toolie's profile
toolie
2120 posts in 2597 days
#1 posted 06-19-2013 08:01 PM
only if the power is really needed. whatever your intentions are, try a better/different blade first. much less expensive and less risky than a motor swap out.
View Tedstor's profile
Tedstor
1643 posts in 2602 days
#2 posted 06-19-2013 08:15 PM
I have the same machine.As long as the mounting plates and pulley shafts are the same size, it should be an easy swap.
BUT
I’m not sure what you’ll accomplish with a 1.5hp motor though. Heavy duty resawing of extremely thick hardwoods might call for a motor that size. I doubt you’ll benefit much with a 14” bandsaw with a 6” throat.
I’d stick with the .75hp. If you really think you need a machine that can resaw 10” hardwoods, you might consider upgrading to a 17-18” machine that is designed for such tasks.
Hermando
#3 posted 06-19-2013 08:20 PM
I guess its the thought of putting a V8 into a pinto so you could get more power, but its still a pinto underneath. You are right the saw does have it limitations and maybe a better investment would be to sell this one and get a bigger better saw designed for resawing and having better precision.
If only money grew on trees and then wood working would not cost so much.
View Brandon's profile
Brandon
4152 posts in 2920 days
#4 posted 06-19-2013 08:26 PM
I always hated my Ridgid 14” bandsaw, that is until I installed a 3/4” timberwolf blade and now it’s pretty good for resawing (as long as the wood fits). Also, I haven’t had any issues with the motor HP.
-- "hold fast to that which is good"
Hermando
#5 posted 06-19-2013 08:37 PM
The advice is certainly appreciated, I may keep my original set up. I was curious what others might have done or suggest. I came across a decent 1 1/2 induction motor for 40$ and thought it would be a good upgrade. I might just keep as a spare or resell.. Unless there are some other ideas it could be used for. I thought also maybe getting a vintage TS cheap and restoring with a good motor.
I guess as much as I do enjoy wood working the tools we use are just as much a part of it all.
View TorxNut's profile
TorxNut
58 posts in 1866 days
#6 posted 06-20-2013 01:19 AM
Hey, what’s the worst that can happen? Snap a shaft off? You already have the motor so give it a try. I have a 1HP Shop Fox 14” BS and wish it had a little more grunt for resawing. With your Ridgid, I believe a weak area is the the motor mounting so make sure that’s reinforced well.
I have a generic floor standing drill press that had a 1/3 hp motor. It was pretty weak for big Forstner bits so when I came across a nice 3/4 hp Baldor for a good price I did a motor swap. I’ve been happy as a clam with my DP ever since.
Bill
