Lawn mower blade as tool steel?
« back to Hand Tools forum
Forum topic by jtriggs posted 06-19-2013 06:28 PM 5941 views 0 times favorited 12 replies Add to Favorites Watch
View jtriggs's profile
jtriggs
181 posts in 3867 days
06-19-2013 06:28 PM
Topic tags/keywords: tool tool steel lawn mower blade
I’ve heard of using old reciprocating saw blades as a source of thin tool steel. What would be the result if you used an old lawn mowing blade for a thicker profile? It would seem to be a cheap alternative to going and buying tool steel somewhere.
Thanks for any advice.
Jon
-- Jon --Always remember, never live your life by a motto.
12 replies so far
View scotsman9's profile
scotsman9
134 posts in 1939 days
#1 posted 06-19-2013 06:36 PM
Lawn mower blades by standard are made of extremely soft steel. They have to bend and dent when hitting rocks and other hard debris. If they were made of tool grade steels, they would shatter and become missiles. So, manufacturers make them with soft soft soft steel.
I’m not quiet certain, but I think the Feds of an allowable hardness for lawn mower blades.
-- Just a man and his opinion.
View Nomad62's profile
Nomad62
726 posts in 3008 days
#2 posted 06-19-2013 06:43 PM
There’re just not the same thing, kind of like brass vs bronze; there are differing amounts of carbon (in the steel) in each, and they are made and formed differently. You could never get the soft metal of a mower blade to do the work of tool or stainless steel.
View Buckethead's profile
Buckethead
3194 posts in 1919 days
#3 posted 06-19-2013 06:44 PM
I’ve heard the Egyptian Great Pyramid’s stones were cut partly using copper tools, but then again, I’ve also heard they were built by aliens.
So as long as an alien is wielding the tool made from the softer steel, it should be fine. :-)
-- Support woodworking hand models. Buy me a sawstop.
View crank49's profile
crank49
4032 posts in 3021 days
#4 posted 06-19-2013 07:19 PM
My former employer makes cast alloy iron with a hardness that surpasses most tool steel, Rc 62 to 65 but is used in blow bars and hammers for hammer mills. These wear parts are designed for extreme hardness and impact resistance. Hardness does not directly relate to toughness and impact resistance.
Also, generally stainless steel is softer than even mild steel, with the exception of the 400 series. And the 400 series, although it can be hardened to Rc 60 or so, is a nightmare to sharpen.
Anyway, the blades of a rotary mower are designed for toughness and not necessarily hardness, as was already stated. But, it is possible they could be hardened by heat treating.
View bondogaposis's profile
bondogaposis
4820 posts in 2401 days
#5 posted 06-19-2013 09:40 PM
It depends what you want to make with it. A similar sized bar of O1 tool steel from Mcmaster Carr might cost double what you could buy a lawn mower blade for, but it will be all useable, with out all of the bends etc. The nice thing about working w/ tool steel is that you can do all of the shaping, drilling, etc. before you harden it. Where as if you have ever tried to drill a hole in reciprocating saw blade you know what I am talking about, impossible.
-- Bondo Gaposis
View waho6o9's profile
waho6o9
8237 posts in 2627 days
#6 posted 06-19-2013 10:12 PM
http://www.harborfreight.com/5-piece-m2-high-speed-steel-mini-tool-bits-for-metalworking-lathes-40641.html
Here’s a good alternative for a good quality HSS that’s cost effective.
View Jim Finn's profile
Jim Finn
2661 posts in 2972 days
#7 posted 06-19-2013 10:42 PM
We used top use old auto leaf springs to make tools with.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
jtriggs
#8 posted 06-19-2013 11:01 PM
Thanks everyone for the swift replies. You’re right of course, I’ve seen enough dented blades on a mower to know that is softer than tool steel should be. Thanks for the other suggestions.
This is the smartest place on the web.
Jon
View Tim Scoville's profile
Tim Scoville
97 posts in 3385 days
#9 posted 06-19-2013 11:28 PM
During my trips to Asia, it was common to see lathe tools made from steel files as these are normally hardened and keep an edge pretty well.
-- Tim S, WA
View casual1carpenter's profile
casual1carpenter
354 posts in 2526 days
#10 posted 06-19-2013 11:35 PM
Jim, we have used leaf springs also, but you can not be real aggressive with grinding and shaping, as they can become brittle. Also without real information and actual material specifications you would need to be mindful of things not blowing apart before your very eyes. Some how I’m thinking lathe tools and a brittle type failure here. I came with two eyes and other various body parts and would really like to keep them.
View Loren's profile
10476 posts in 3698 days
#11 posted 06-20-2013 01:14 AM
I know swordmakers make swords from them. I don’t
know if they hold an edge though… these days most
handmade swords are made for show and aren’t
sharpened for safety reasons.
View Jim Baldwin's profile
Jim Baldwin
56 posts in 2408 days
#12 posted 06-20-2013 04:48 AM
As a rule, if you can file the metal than it’s soft steel (lawnmower blades are sharpened with a file). If the file slides across without removing material, than it’s hard. Of course soft steel can be hardened by heating and quenching (machine shop 101). In general all old handsaws, circular, band and hack saw blades are good tool steel as well as old files. Gardening tools are not hard with the exception of the machete which is good spring steel. Don’t overlook old putty knives and scrapers which are also hard.
Do I have to say “never use scrap steel as knives, in powered rotating equipment? (homemade junk kills people).
-- Jim Baldwin/jimhbaldwin@gmail.com
