Fabbing PC edge guide to work with ridgid palm router?
Forum topic by lateralus819 posted 06-18-2013 10:43 PM 1033 views 0 times favorited 4 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 2004 days
06-18-2013 10:43 PM
I was looking into building a micro adjusting edge guide for my router, then i noticed this porter cable guide. http://www.amazon.com/dp/B0000222V9
Looks like by making a new front mounting plate, with holes and set screws, it would work. Any ideas?
View NiteWalker's profile
NiteWalker
2737 posts in 2691 days
#1 posted 06-19-2013 12:28 AM
Yep, looking at the pc edge guide pics, all you would need is a new front piece that holds the bars and a way to lock the ridgid bars in place.
View FirehouseWoodworking's profile
716 posts in 3388 days
#2 posted 06-19-2013 12:29 AM
I like mine very much, though I don’t use it that often. I use it on my Porter Cable D-Handle base and it works great. Good luck.
Cheers!
-- Dave; Lansing, Kansas
View TorxNut's profile
TorxNut
58 posts in 2012 days
#3 posted 06-19-2013 02:31 AM
I just looked at my Ridgid R2401. It looks like the edge guide bars are 5/16” diameter on about 2-5/16” centers
(8mm/58mm?). Too bad I don’t have a PC router to measure other than a jumbo 7518.
Anyway, I’ll bet you could make it work. If you were really, really, lucky, maybe one of the PC’s spacings would fit the Ridgid. I can see on the link’s picture that the guide is drilled for more than one bar position. If that didn’t work, maybe you could re-drill the plate that comes with the guide instead of making a new one from scratch.
Bill
5065 posts in 2608 days
#4 posted 06-19-2013 01:38 PM
I have that edge guide and use it often, usually on my Milwaukee routers. It’s an awesome edge guide (if there such a thing). Anyway, the front plate has 2 sets of holes in it…both are threaded 1/4-20, and they apparently fit 2 sizes of PC routers. The narrow set of holes is 2 3/8” center to center, the wider set is 3” CtC. The posts included with the guide didn’t fit my Milwaukee bases, so I made my own by cutting off some 1/4-20 bolts to fit the guide. Then to increase the diameter to fit the Milwaukee base, I epoxied some brass tubing on tot the bolts shank, I got almost 5/16” (close enough) byu doing that. Works great, and can still be quickly converted back if I want to stick it on my 690.
