Seeking advice on building a double door unit for outdoor shed
Forum topic by mrcando posted 06-18-2013 06:08 PM 4265 views 0 times favorited 6 replies Add to Favorites Watch
View mrcando's profile
mrcando
13 posts in 3226 days
06-18-2013 06:08 PM
Topic tags/keywords: double door wood shed question
This is a long shot, but I was wondering if anyone has built or has seen plans to build a double outswing door unit suitable for a utility building, or in my case a 8’ by 12’ bldg. to be built for air drying wood. My goal is to use two 36” exterior steel clad doors which I will build the jambs, etc. for. I already have one left hand door and will have to find a matching right hand one.It will probably be fairly straightforward, but any ideas or suggestions such as security hinges, weather seal, etc. would be appreciated. Thanks, guys
User avatar
phil
-- Phil
View dannelson's profile
dannelson
193 posts in 2399 days
#1 posted 06-18-2013 08:08 PM
this is what i did for my shop. if your air drying why the weather shield? over size the jamb width and build an astrical down the center . as far as hinges get some ball bearing ones that have a set screw that locks the hinge pin to prevent it from being lifted
-- nelson woodcrafters
View Clint Searl's profile
Clint Searl
1533 posts in 2389 days
#2 posted 06-18-2013 08:18 PM
Good advice; I did the same (though not as elegant) for my garage shop. Since I wanted it insulated, I made frames out of 2×4’s, skinned outside with T1-11, and inside with 1/2” chip board.
dannelson
#3 posted 06-18-2013 08:33 PM
I built it the same way except 1/2 smooth ply on the outside 1x trim, 3/8 inside, insulated with 1-1/2 foam. Inside that I kept the old garage doors and knocked out all the panels and replaced them with glass.
mrcando
#4 posted 06-19-2013 04:58 PM
Thanks for the response guys. dannelson, in reference to your query about the weather shield, it’s really nothing to do with the weather, but all to do with pest intrusion. I live deep in the woods and constantly must deal with mice, wasps, etc. I plan to install a couple of power vents on the roof and screen covered air intake vents at floor level in the walls around the bldg. By the way, that’s a nice shop you have there.
-- Phil
13609 posts in 3369 days
#5 posted 06-19-2013 05:03 PM
here is what i did for my spray booth build
if you are looking for seals
these are the best i have found
http://lumberjocks.com/patron/blog/36455
View justineburton's profile
justineburton
3 posts in 1299 days
#6 posted 12-03-2014 04:48 AM
That is always possible provided you have the required space. Anyway, you can try also try to use pre-hang Interior doors at http://caldwells.com/door-shop, this is what I used in my garage.
