Refinishing 50 year furniture with old oil /wax
Forum topic by NEwtoowood posted 06-18-2013 12:53 PM 1287 views 0 times favorited 8 replies Add to Favorites Watch
View NEwtoowood's profile
NEwtoowood
7 posts in 1997 days
06-18-2013 12:53 PM
Topic tags/keywords: restoring old furniture
Help ! I was talked into (actually conned) refinishing some 50 old furniture from my parents. Its a 6 piece book case (tops and bottoms) that was supposed to be all solid walnut. Unfortunately its walnut veneer which makes its a bit more difficult to refinish. The biggest hurdle is that the finish is oil/ wax not varnish. My parents oiled this stuff several times a year and it can not sand through it, even with a belt sander and 80 grit. The sand paper instantly clogs.
Does anyone know of a way to pre clean the surface to make sanding easier? I tries mineral spirits with no luck.
The surface needs to be thoroughly sanded as the there are deep scratches and the color is a bit ugly. At this point I am willing to risk ruining the furniture as I hate spending this much time on veneer. Really wanted it to be solid wood.
Any help is appreciated !!
8 replies so far
View Bill White's profile
Bill White
4859 posts in 3867 days
#1 posted 06-18-2013 01:30 PM
Have you tried using naptha to remove the old wax?
Bill
-- bill@magraphics.us
View Clint Searl's profile
Clint Searl
1533 posts in 2268 days
#2 posted 06-18-2013 02:02 PM
Use a stripper. Don’t sand.
NEwtoowood
#3 posted 06-18-2013 02:24 PM
Bill thanks for the tip. I will try naptha.
Clint , there is not clear or varnish. Only linseed oil wax. Will stripper remove that build up?
View mpounders's profile
mpounders
869 posts in 2802 days
#4 posted 06-18-2013 02:29 PM
You’ll chew up that veneer pretty quick with 80 grit sandpaper. Use furniture stripper and steel wool.
-- Mike P., Arkansas, http://mikepounders.weebly.com
Clint Searl
#5 posted 06-18-2013 08:28 PM
A methylene chloride (MEC) based stripper will work better than anything. Follow up with a good scrubdown with naptha and maroon scotchbrite.
View Finisherman's profile
Finisherman
227 posts in 1756 days
#6 posted 06-19-2013 02:47 AM
First of all, please don’t try to sand off the finish, especially not with 80 grit paper on a belt sander. At best, you’ll waste sanding belts without achieving much. More likely you’ll burn through the veneer. I’ve always found that attempting to abrade off a finish amounts to little more than an exercise in frustration. As Clint said, you’d be much better off using a methylene chloride stripper to remove the finish. I would also add that you might want to try lacquer thinneer or acetone in place of mineral spirits or naphtha when you scrub down the piece after stripping. Naphtha or mineral spirits will disolve wax, but they won’t dissolve cured linseed oil. I would also suggest that you plan to seal the wood with dewaxed shellac prior to finishing. This will seal in any residual wax and help to prevent adhesion problems when you apply your finish.
View DaleM's profile
DaleM
958 posts in 3291 days
#7 posted 06-19-2013 02:54 AM
I would use a card scraper and a stripper. Remove as much as you can with the scraper, then apply the stripper and scrape again if needed. I’m surprise Clint didn’t mention that oil and wax are not finishes, hahaha.
-- Dale Manning, Carthage, NY
NEwtoowood
#8 posted 06-19-2013 02:31 PM
Thank you all for the help. I will try the stripper.
