| Forum topic by USCJeff | posted 535 days ago | 193 views | 0 times favorited | 4 replies | ![]() |
535 days ago |
I’m always looking for ways to use my scraps as I’m proud of being cheap! I want to build a drum sanding table for my drill press. I found a simple design that gets the job done and is also easy to attach or remove. I however, don’t own any sanding drums for a drill press. They aren’t that expensive, but I was thinking it would be easy to make some. My thought is that you could take different sizes of dowels and adhere sandpaper to them. I would think I could drill a hole in the dowel to accept a bolt. You could put an insert or T-nut to thread the bolt. You could then chuck the bolt into the drill press. I would think you would have to prevent the bolt from “unthreading”. Lock washer or embedded nut maybe. What do you think? Any issues that come to mind? -- Jeff, South Carolina |
