Jointer table not level
Forum topic by MrRon posted 06-17-2013 04:34 PM 1081 views 0 times favorited 3 replies Add to Favorites Watch
View MrRon's profile
MrRon
4633 posts in 3150 days
06-17-2013 04:34 PM
Topic tags/keywords: jointer
I have a Powermatic 6” jointer and I’m pretty sure the tables are not co-planar. I understand that this can be corrected by shimming the tables. I can do this easily with the out-feed table because this is set once and left alone. The in-feed table is different. If I shim it and readjust for depth of cut, won’t the level be changed?
3 replies so far
View pintodeluxe's profile
pintodeluxe
5568 posts in 2720 days
#1 posted 06-17-2013 04:39 PM
Take a 4’ straightedge, and check the tables for co-planar. Use a feeler gauge with a .002” feeler to see how far it is off. Your Powermatic may be like my Jet, where there are gib screws that can make the adjustments, rather than brass shims. That way the alignment won’t be affected by changing depth of cut.
View unbob's profile
unbob
802 posts in 1810 days
#2 posted 06-17-2013 08:36 PM
I would suggest removing the tables and cleaning/lubing the sliding ways.
Adjust the gibs so as they allow the table to just move smoothly, too loose the ends of the tables will sag.
It doesnt take much gummy build up to throw the tables out.
At least at that point, testing with a straight edge, can get a better idea of what is going on.
View knotheadswoodshed's profile
knotheadswoodshed
212 posts in 2079 days
#3 posted 06-18-2013 01:35 AM
dont try using the IGaging straight edges, the ones I just got ( 3 piece set) are not even close to being “straight”, with the 24” being the worst
-- Randy - "I dont make mistakes, I make design change opportunities" www.knotheadswoodshed.com
