splicing inlay banding.
Forum topic by lateralus819 posted 06-17-2013 12:55 PM 1015 views 0 times favorited 4 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 2087 days
06-17-2013 12:55 PM
Hello all. I’m building a hall table right now whose front apron is 42” long ans the top is 48” long. Is like to do inlay banding on the edge of the top and botttom of the front apron, but the bandings only come in 36” lengths. Has any one ran into this problem and how did you dealwith it. I talked to matt at inlaybandings and he saida banding with a pattern would be most suited to splicing. Thanks
View Wdwerker's profile
Wdwerker
333 posts in 2431 days
#1 posted 06-17-2013 03:05 PM
A long scarf joint with the pattern matching is the least detectable . Shooting board and a sharp plane is one approach. Straight edge and a razor knife will work if you are careful.
-- Fine Custom Woodwork since 1978
View Loren's profile
10477 posts in 3846 days
#2 posted 06-17-2013 03:30 PM
Concur, scarf.
I use scarf joints on guitar binding. The first time I
noticed a guitar done that way, I thought it would
be tricky, but it’s not. With a banding you do want
to be careful about chipping out the banding material
as you cut the scarfs. Fool around and practice a
bit…. you may find the inside of the banding prone
to crumbling and that you need to sneak up on a good
fit with sandpaper instead of a chisel.
lateralus819
#3 posted 06-17-2013 11:25 PM
What angle should the scarfs be cut? Is 45 enough? And this may be a stupid question but how do scarf joints minimize the “splice” is it due to the fact that you don’t actually see it head on moreso from its side. therefor its almost eliminated?
View Tony Strupulis's profile
Tony Strupulis
260 posts in 3321 days
#4 posted 06-28-2013 03:51 AM
If it is a plain banding, I agree to scarf it. If it has some kind of repeating geometric pattern such as a checkerboard, you might have to do a butt joint at a break in the pattern.
-- Tony - http://ravensedgetoolworks.com
