Salvage split pot?
« back to Woodturning forum
Forum topic by Octavius posted 06-16-2013 04:42 PM 1093 views 0 times favorited 15 replies Add to Favorites Watch
View Octavius's profile
Octavius
60 posts in 3043 days
06-16-2013 04:42 PM
This spalted wood is very cool so am prepared to do whatever is necessary to repair the splits.
I don’t know, carpenters glue mixed with fine saw dust? Don’t they sell a gap-filling epoxy?
Or should I just move on.
Cheers!
15 replies so far
View OnlyJustME's profile
OnlyJustME
1562 posts in 2247 days
#1 posted 06-16-2013 07:59 PM
If it were me i would move on. it looks like you have quite a few other checks and cracks that could probably come apart as you are further along in the turning. Is this green wood you are turning?
-- In the end, when your life flashes before your eyes, will you like what you see?
Octavius
#2 posted 06-16-2013 08:52 PM
Thanks for the reply.
It came from a dead dogwood that I cut down a couple of weeks ago. It feels quite dry and the shaving are not wet at all. Dogwood is only a small tree so that is basically the trunk we are looking at with the bark removed. I’ve a 50/50 success rate on this tree and another dogwood I cut down years ago. The conventional wisdom is that the trunk should be quartered otherwise checks are inevitable.
I cut down a small oak a while back and that thing checked just looking at it.
Dogwood is my favorite wood for turning by far so far – it gives a very smooth finish – one pot I made almost looks/feels like porcelain.
Cheers!
OnlyJustME
#3 posted 06-16-2013 09:27 PM
Dogwood is also great for carving. gives very clean and smooth results. such a shame it stays so small. some guys use CA glue to glue it but it looks like you might be doing that a few more times as you go on unless the one crack relieved enough stress that the rest of it will be fine. I’m not very experienced in turning yet so i always error on the side of caution.
View TheDane's profile
TheDane
5348 posts in 3533 days
#4 posted 06-16-2013 11:47 PM
Get some 30-miute epoxy, mix in some sawdust from the shavings you made when you turned this, and fill the cracks.
When you fill cracks that are as wide as this, it is advisable to put duct tape or masking tape on one side of the crack, or you will have epoxy all over your bench, your shop, and yourself. Don’t ask me how I know.
If you want to jazz it up, mix something other than sawdust into the epoxy. One of my buds goes to a locksmith shop and picks up the filings from their key-making machine. He mixes that into epoxy, sands and finishes for a real nice effect. He also uses crushed stone (like turquoise) for some of his stuff.
OnlyJustME
#5 posted 06-16-2013 11:52 PM
Is that before or after being done turning it? Sounds like that would tear up a gouge edge trying to finish the piece with metal or stone in the epoxy.
Octavius
#6 posted 06-17-2013 12:00 AM
Thanks the Dane – I’m on it.
TheDane
#7 posted 06-17-2013 12:11 AM
OnlyJustME … You would do the epoxy first (overfill the gap a bit), then finish turning when it is cured. The epoxy may be a little cloudy when you turn it, but when you apply the finish (lacquer, shellac, poly, etc.) it should look good.
I didn’t put any ‘accents’ in it, but this bowl has a load of epoxy that was used to fill voids:
Click for details
P.S. I expected the pith to crack or warp in the bowl referenced above, but so far, so good. I finished it about 8 months ago so I think I dodged the bullet.
View bondogaposis's profile
bondogaposis
4524 posts in 2221 days
#8 posted 06-17-2013 12:16 AM
I like to fill cracks like that w/ epoxy and abalone shell, rather than trying to hide them accentuate them. It won’t harm your tools.
-- Bondo Gaposis
OnlyJustME
#9 posted 06-17-2013 12:26 AM
cool.
Octavius
#10 posted 06-18-2013 07:40 PM
Thanks again The Dane – I salvaged the pot for my pens. Big crack is to the left. No abalone, sorry Bondo, just sawdust/epoxy.
Cheers!
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3455 days
#11 posted 06-18-2013 08:46 PM
I would advise you to throw away or burn these pieces of badly split wood.
I nearly lost my thumb and spent 10 days AND MANY hours of micro surgery and wore metal clamps etc for weeks all is ok now but hey it’s just not worthg the chance imho. SO I SAY definitely not that is my advice. Alistair
Octavius
#12 posted 06-18-2013 08:55 PM
Oh, wow. I’m sorry to hear that Alistair. I’m glad they could save your thumb but it must have been a horrible experience.
Regards.
View Wildwood's profile
Wildwood
2204 posts in 2005 days
#13 posted 06-19-2013 03:54 PM
There is a saying in woodturning community about not turning junk wood. Agreeing more and more with that statement due to safety concerns and time wasted. Because have been there and done that.
Filling voids and cracks just not for me unless it adds to aesthetics of the piece. Only an amateur would call attention to flaws in piece of wood without adding to overall composition.
Yes, still try to salvage a piece when unexpected flaws in wood show up. If cannot turn away that flaw safely, just leave it alone or toss it.
I am not advocating do not try to salvage a piece, just evaluate safety and final look of the piece. Here is a few examples of time wasters with all their flaws.
-- Bill
Octavius
#14 posted 06-19-2013 04:34 PM
Thanks for your voice of experience, Bill.
Unfortunate, isn’t it, that the “junk” wood is the most interesting in terms of figure, imperfections, etc.
Cheers!
Wildwood
#15 posted 06-19-2013 08:36 PM
Grain orientation can help a lot too!
I have turned a lot of spalted wood. I personally would not have continued turning your piece of wood into a pen cup for two reasons. One, wood not really interesting and second would always see that split. Yes, you did a remarkable save and serves the purpose for which intended.
Take a look at some better examples of spalted wood turned items.
https://www.google.com/search?site=imghp&tbm=isch&source=hp&biw=1280&bih=652&q=spalted+wood+turnings&oq=spalted+wood+turnings&gs_l=img.3...1047.6631.0.6922.21.10.0.11.11.0.128.1190.0j10.10.0...0.0...1ac.1.17.img.hS8tznwMh80
-- Bill
