I've been looking around for a new table saw for a while now. I currently own a $150 skil saw which is ok but doesn't give me nearly the accuracy I need for some of my newer projects. It also seems somewhat unsafe since the safety mechs aren't fully functional. Anyways, I have been looking on Craigslist for a good deal and everything is overpriced or from the 60s. So I am wondering what you guys thought about the DEWALT 15 Amp 10-in Table Saw
or any other table saw under $400. I want good capacity, quality, and hopefully some kind of dust collection because I can never keep my shop clean with my current table saw. I was thinking with the dewalt I could build a table for it and leave a hole for dust collection. What do you guys think?
How will you use it ? does it stay in one place or go from job to job . A good fense is important ,one you do not need to check for set every cut .some old saws have great after market fenses . you need an out feed ,you just do .Safer and more accurate not to be balancing boards on a small saw top when pushing them through . newer saws are more likely to have a riving knife though on small cheap saws if the blade binds you can just stall the motor and get the board out -though still not safe . I did all my carpentry,rough ,finish and trim on a 8" makita with a good stand for over 10yrs . The stand was the factor -it has a great fense and an out feed table .Power and blade size was not an issue .even did melimine on it with the right blade .
that dewalt has a good fense -you need to make an out feed .
Just got back from Inside Passage School, 2 classes down 8 to go, What are you building? Consider a good Band saw as a better investment. Last year I bought a great 10in. Delta cabinet saw and a older 14in. band saw.
Built two Kernov planes and totally amazed as to the quality of the shavings I can now create!
For clarity, the DW 15 amp saws are portable job site saws, not what most of us consider a contractor saw. Portability is the main advantage of a jobsite saw, otherwise nearly every advantage is in favor of a decent full size contractor saw with a belt drive induction motor, so if you don't need to transport the saw from site to site, I'd definitely suggest a belt drive contractor saw. There is no clear "best" IMO…most actually have pretty similar basics, and many come from the same plants regardless of the name plate. It's things like the fence, belt drive system, and wing material that make the most difference. The end performance will be largely determined by setup and blade choice.
reviewing KS's thread is a good starting point. and it would be, IMHO, unwise to discount a tool based solely on it's age. i have two emerson electric built 10" CI TSs. they are clones of each other, just built ~25 years apart. while they function the same, the innards of the older saw have solid webbing in castings where the guts of the newer saw have hollowed out spaces in the webbing, primarily in an effort the save costs. sometimes, "they don't build them like they used to" is valid and can provide a good value in a well performing power tool. just my $.02.
I'm going to break the rules here. I know the price tag is important. It's always important to me. Since I don't have work space, I had to buy a contractor saw. I looked everywhere and read all the reviews. I spoke with a lot of people. The message I got was consistent. Bosch.
It was $150 more than I hoped to spend but with all the accolades and comparative reviews, I bit the bullet. So far I am extremely happy I went the extra 150.
Here is my non specific advise. If 150 separates you from what you feel is the best, keep thinking about it. Once you have bought and used your in-budget product for a while, will you wish you had thrown in the extra bucks especially when you were so close?
By the way. In my opinion. I liked the rigid fence and set up better than the Dewalt. In my limited experience, I have found Dewalt guts to be better.
You just got alot of great advice . All very consistant .Your answer is in there . I agree with the comments made about the dewalt . I think you can find a good saw pretty cheap . Keep looking
A Ridgid 3650 is a good contractors saw that can be found for $250-325. A Ridgid R4511 granite top is a better saw (hybrid) that can be found for $350-425. Both saws are 120 volt, 1 1/2 HP, left tilt, and a craftsman riving knife will fit the 4511. Either saw will do a good job for most woodworkers. Just be patient and take your time looking.
I really like the fence on the dewalt, I have owned both the larger dewalt and the smaller dewalt jobsite saws and both had solid motors. I really like the dewalt fold up stand as well. I have owned a Bosch and it is a solid second option. I also have heard that the new makita saw has a blade brake but I'm not sure about the fence. I have used the ridgid and would point you in a different direction.
Mike pointed out that this saw will not accept dado blades, while that is true, if your table saw is this small you would probably be better off using a router anyway. I wouldn't put a dado blade in any jobsite saw, I would have no hesitation with a decent contractor saw though.
Thank you guys for your awesome advice. To answer your questions, I do not need jobsite capabilities but I thought maybe it would be better quality since it's a Dewalt.
Not taking a dado stack would be a deal killer for me. The Bosch sounds like a really good saw, but
you could get a full sized excellent used contractor saw for much less, about half of what a
Bosch costs.
Or, a Ridgid 4512 for about 50 or so dollars less than the Bosch.
Depends on your budget and space . If space is limited, the Bosch seems to be the best in
the class of jobsite saws.
"Thank you guys for your awesome advice. To answer your questions, I do not need jobsite capabilities but I thought maybe it would be better quality since it's a Dewalt."
Jobsite saws just don't have the mass, stability, operating room, torque, smoothness, materials of construction, reliability, standardization, or upgrade potential of a decent full size contractor or hybrid saw with a belt drive induction motor. They're basically a beefy circular saw mounted to an aluminum table inside a plastic body. Portability is their forte….all other advantages swing heavily in favor of the more robust saws, "almost" regardless of brand name. Table Saw Info
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
