Using CA glue
Forum topic by MrRon posted 06-15-2013 04:48 PM 1163 views 0 times favorited 12 replies Add to Favorites Watch
View MrRon's profile
MrRon
4718 posts in 3209 days
06-15-2013 04:48 PM
I want to use CA glue to seal end grain and the edges of plywood (Baltic Birch). What is the best way to do this. If I were to use a brush, the bristles would be glued to the wood, right? Would dipping the wood into the CA work?
12 replies so far
View cutmantom's profile
cutmantom
402 posts in 3001 days
#1 posted 06-15-2013 05:00 PM
i would something else, CA i think would be kind of expensive to use for this, shellac or lacquer would work and dry fast
MrRon
#2 posted 06-15-2013 10:59 PM
I’m building models using 1/2” Baltic Birch and will be drilling 1/8” dia holes in the end grain. The holes are 1/4” through holes. I don’t want the BB to delaminate, so the area involved is quite small. Someone else recommended CA, so I thought I would go with that.
HillbillyShooter
5811 posts in 2258 days
#3 posted 06-15-2013 11:21 PM
I use CA glue (thin variety as opposed to the thick type) on the ends of BB for dovetail drawers cut with my Leigh jig. It helps but is not a total solution for avoiding blow out. Titebond sells larger sizes which help cut the cost. My approach is to set the sides/back/front on end between a couple of 2xs to apply to the top end grains with the applicator bottle the CA comes in, leaving the BB pieces vertical for an hour or overnight, and then doing the other end. Simple but a little time consuming. I usually try to do this on evenings during the week when my shop time is at a minimum due to work.
View Benvolio's profile
Benvolio
148 posts in 1897 days
#4 posted 06-15-2013 11:28 PM
on a related note – does anyone know the correct solvent for thinning CA glue??
-- Ben, England.
View gfadvm's profile
gfadvm
14940 posts in 2656 days
#5 posted 06-16-2013 01:57 AM
Seems to me that epoxy would be a lot quicker, cheaper,and stronger.
HillbillyShooter
#6 posted 06-16-2013 02:24 AM
My thought was that epoxy would be thicker and capillary action would not soak the glue as deep into the end grain as the capillary action would carry a thin CA glue. Using 1/2”BB, the CA should soak down the right depth for a dovetail joint. JMHO.
PS. The stores carry a solvent for CA glue; otherwise I’d probably start with acetone.
gfadvm
#7 posted 06-16-2013 02:50 AM
I misunderstood your need to get that much penetration so I agree that epoxy won’t go that deep. But I don’t think CA will either.
HillbillyShooter
#8 posted 06-16-2013 03:31 AM
Actually, after posting I remembered the idea for using CA glue like I mentioned originated from the construction details shared by another LJ:
http://lumberjocks.com/projects/71665
As I often observe, there are very few new ideas—just a lot of rediscovered ones.
View Woodknack's profile (online now)
Woodknack
11478 posts in 2346 days
#9 posted 06-16-2013 08:36 PM
Acetone is the solvent for CA but I have no idea if it can be used properly as a thinner.
View oldnovice's profile
oldnovice
6770 posts in 3333 days
#10 posted 06-16-2013 10:40 PM
I have used wall board patching compound (spackling paste) which works fine if you are going to paint the edges. I put it on with a putty knife and after it dries, sand it and paint it!
View Dan Lyke's profile
Dan Lyke
1519 posts in 4091 days
#11 posted 06-21-2013 08:40 PM
You can get some pretty amazingly thin epoxies (look in the rot repair section of your hardware store, they make super runny epoxy that’s made to soak into wood).
I use the runny CA for gap filling all the time, and I’d just put that edge of the plywood up and pour the CA on it. Then maybe use some parallel jaw clamps to squeeze the heck out of the plywood in that area.
View brtech's profile
brtech
1028 posts in 2888 days
#12 posted 06-21-2013 09:46 PM
I don’t think CA sticks to silicone, so you might be able to use a silicone brush. Dipping clearly works. Thin CA is like water, and wicks like water.
You can’t thin CA with acetone. It’s a solvent, but not a thinner. If your CA is thick because it’s old, throw it away,
the problem is irreversible.
