What kind of wood should I use for a platform that holds 200 lbs
Forum topic by justinliang posted 06-12-2013 07:48 AM 1611 views 0 times favorited 9 replies Add to Favorites Watch
View justinliang's profile
justinliang
1 post in 1779 days
06-12-2013 07:48 AM
Topic tags/keywords: wooden platform material
I am making a flat platform with 4 leveling feet that can hold a heavy duty blower which is around 200 lbs. The platform is 21.5” x 22.5” as shown in this image (let me know if there are better designs).
I thought about using 0.5” steel plate but with these dimensions, it will cost me $200+. That is why I decided wood would be a good option although I am not sure what type of wood to use. What I need is something strong, will dampen vibrations from the blower and costs less than $100 (the cheaper the better).
This will be indoors and will be a raised platform, I was thinking of using Heavy Duty Vibration-Damping Leveling Mounts.
I heard that I can use 2x’s to build a platform. What dimension 2x’s should I use and I am guessing I would put them side by side to form a platform similar to hardwood floors?
9 replies so far
View madts's profile
madts
1855 posts in 2308 days
#1 posted 06-12-2013 08:16 AM
A torsion box made from 1/2” Baltic birch would be more than adequate.
-- Thor and Odin are still the greatest of Gods.
View Woodbum's profile
Woodbum
808 posts in 3034 days
#2 posted 06-12-2013 06:21 PM
Dimensional framing lumber OS frame with cross bracing OC @ 7” capped with 3/5 ply is more than enough for 200lbs. 2×4s will be OK or 2×6s whatever you have laying around.
-- "Now I'm just another old guy wearing funny clothes"
View RussellAP's profile
RussellAP
3103 posts in 2255 days
#3 posted 06-12-2013 06:28 PM
Two-by’s on end will hold it.
View brtech's profile
brtech
1028 posts in 2891 days
#4 posted 06-12-2013 06:34 PM
I would build a 2×4 frame (4 sides) with two extra supports (7-8” OC). The 2×4s would be on edge. Then skin both sides with ply. If $100 is your budget, might as well use 3/4, but 1/2” would probably work.
Glue and screw the joints. Put the leveling feet into the 2×4 an inch or two from the joints. I’d probably drill a hole and knock a T nut into it and then thread the foot into that.
brtech
#5 posted 06-12-2013 06:38 PM
Oh, yeah, one more idea: Most blowers have mounting feet or arms. They don’t distribute the weight over a large area. If yours is like that, make sure the mount for the blower is under a support 2×4. Better to have uneven spacing with the supports and have a support under the weight bearing part of the blower than to have the spacing even and have the blower supported by the ply. You will have two 2×4 x 8s in this, so an extra support is okay.
View helluvawreck's profile
helluvawreck
30765 posts in 2835 days
#6 posted 06-12-2013 06:46 PM
200lbs is not much heavier than an average size man would be. A man can stand on a good three legged stool. Obviously, you would want to make it sturdier that a three legged stool but you get the idea. You could do it with your design that you have drawn out or with hundreds of other designs. Hard rubber pads make good dampers and I’ve got to assume that your blower is not so out of balance that it’s going to shake your shop to pieces. It would also be bolted to the floor I would imagine.
helluvawreck aka Charles
View junebug's profile
junebug
101 posts in 2373 days
#7 posted 06-12-2013 06:47 PM
keep something in mind.. 200lbs isnt that much. The vibration will be the hardest to deal with
helluvawreck
#8 posted 06-12-2013 06:56 PM
Come to think on it, you could put it outside your shop and just pour a concrete footing for it. In our molding plant we had at least a dozen blowers ranging from 10 HP on up through 75 HP and most of them went outside on a pad and we would put a simple slanted roof cover over them to keep them mostly dry in the rain. The belts had a lot more traction during a hard rain that way.
View Holbs's profile
Holbs
1843 posts in 1998 days
#9 posted 06-12-2013 11:33 PM
for vibration concerns, would a 1/2” MDF torsion box be more suitable than birch plywood?
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
