Elm and Walnut Slabs
Forum topic by docspencer posted 06-11-2013 01:26 PM 1665 views 0 times favorited 9 replies Add to Favorites Watch
View docspencer's profile
docspencer
361 posts in 1971 days
06-11-2013 01:26 PM
Topic tags/keywords: walnut
Had a couple of logs from the woods – one elm and one walnut. The elm was cut this past winter. The walnut was cut at least 7 years ago and has been sitting in the woods. Cut the slabs with my chainsaw – and I found out just how hard it is to cut a straight line!
Quick question – given how old the walnut is, should I stack it for a while or can I start working with it?
9 replies so far
View Wdwerker's profile
Wdwerker
333 posts in 2259 days
#1 posted 06-11-2013 01:36 PM
Weigh the slab and let it sit for a few weeks. Weigh it again. When the weight quits changing you can begin to work it. Or buy a moisture meter.
-- Fine Custom Woodwork since 1978
View Vern Little's profile
Vern Little
103 posts in 3563 days
#2 posted 06-11-2013 10:25 PM
The walnut was cut at least 7 years ago and has been sitting in the woods. You are 61. Get to working with it, or else kiln dry it. It will outlast you. Will it be a slab still, or something you made out of it.
-- Earth first, we'll drill the rest of the planets later. Vern
docspencer
#3 posted 06-12-2013 12:28 AM
You do have a point. LOTS of things are going to outlive me. I’m not sure what to do with it. If I thought enough about it, I could have cut it thicker and made a short bench with a single slab. I may incorporate it into a chip and dip tray I’m planning. Sure does smell nice!
View WDHLT15's profile
WDHLT15
1748 posts in 2502 days
#4 posted 06-12-2013 12:55 AM
The walnut needs to dry. It is not ready, even after all this time. Logs hold moisture for a very long time. A very long time.
View Nomad62's profile
Nomad62
726 posts in 2984 days
#5 posted 06-13-2013 10:05 PM
Likely too wet to use. Even after that much time it will be too moist inside. I’d recommend letting it set for a couple of months.
View KentuckyTreeRat's profile
KentuckyTreeRat
73 posts in 2277 days
#6 posted 06-14-2013 02:42 AM
Even if it were cut 30 yrs ago, if left in the elements you can either sticker and stack it or kiln dry it.
LOL @ Vern.
-- "My glass aint half empty, or half full....I drank it all." -Me www.kentuckyliveedge.com
View Dusty56's profile
Dusty56
11819 posts in 3714 days
#7 posted 06-14-2013 03:46 AM
Still looks wet in the pics. Can’t tell how thick you sliced it , but the old saying is about a year per inch of thickness , depending on the drying conditions.
View rustfever's profile
rustfever
752 posts in 3336 days
#8 posted 06-14-2013 08:50 AM
Logs and stumps do not dry. Only lumber.
The walnut probably has a moisture content of nearly that which it had when it was standing. If you cut it to 3” thick, it will take another 3 to 5 years to dry out to about 10% MC. if you cut to 1” thick, it will be dry next summer.
Just my experience.
-- Rustfever, Central California
docspencer
#9 posted 06-14-2013 09:01 AM
I’m amazed logs hold moisture that long. Thanks for all the feedback guys!
