Broken bit
Forum topic by emiliof posted 06-11-2013 11:36 AM 859 views 0 times favorited 6 replies Add to Favorites Watch
View emiliof's profile
33 posts in 1929 days
06-11-2013 11:36 AM
Topic tags/keywords: question router
I accidentally dropped my router, which had a 2-flute, 1/2” shank, 3/8” straight router bit. It seems that nothing happened to the router but the tip of one of the flutes broke. Actually the flute lost about a half of its surface. I have not used the bit since, just in case it is dangerous.
There are single-flute bits around, so would it be safe to continue using the broken bit?
-- Emilio
View Kaleb the Swede's profile
Kaleb the Swede
1817 posts in 1905 days
#1 posted 06-11-2013 11:50 AM
Straight bits on the whole aren’t that expensive. I would get a new bit, rather then mess up the what I am working on. Maybe the guys who have been doing this longer may have a different opinion, but I myself wouldn’t risk it. If there is a hairline crack that you can’t see now, and it is spinning at the typical RPM’s of a normal router, the whole bit can come apart, and then the ouch begins. Hope this helps
-- Just trying to build something beautiful
View scotsman9's profile
134 posts in 1824 days
#2 posted 06-11-2013 11:53 AM
I agree with the Swede, don’t risk it if it may contain fractures.
-- Just a man and his opinion.
View NiteWalker's profile
2736 posts in 2512 days
#3 posted 06-11-2013 11:53 AM
Don’t use it.
There may be micro fractures in the carbide you can’t see.
Spinning at 20,000+ rpm greatly amplifies the chance for the carbide to shatter in use.
It happened to me with a rockler bit; all looked fine, but when I went to use the bit again, the chipped flute shattered. The workpiece was the only victim, fortunately.
View HorizontalMike's profile
7749 posts in 2850 days
#4 posted 06-11-2013 12:25 PM
FWIW, I once broke an up-twist spiral bit on my horizontal mortise machine when initiating a mortise. I was standing at 90-degrees to the centrifugal force and luckily was not injured. I NEVER found the broken end of the bit. And this was inside of my closed shop. Scary stuff…
#5 posted 06-11-2013 12:37 PM
It didnĀ“t take me 10 seconds to throw the bit to the garbage bin after I read your answers. Thank you all guys!
-- Emilio
View SnowyRiver's profile
51457 posts in 3416 days
#6 posted 06-11-2013 12:47 PM
I agree with everyone too. I wouldnt use it. Buy a new one. It isnt worth the risk.
-- Wayne - Plymouth MN
