Deck repair question
Forum topic by SteveKnnn posted 06-11-2013 04:09 AM 915 views 0 times favorited 5 replies Add to Favorites Watch
View SteveKnnn's profile
SteveKnnn
66 posts in 1972 days
06-11-2013 04:09 AM
(Not sure this is the right forum)
My deck (screen porch) was installed by the builder 5+ years ago of pressure treated lumber.
Nails have started popping. I am inclined to pull any popped nails and replace with slightly longer screws (ceramic coated?, star drive?)
Suggestions please…
Pulling and screwing good idea?
If yes, what type of screws etc.
-- Steve in Richmond, VA
5 replies so far
View mandatory66's profile
mandatory66
202 posts in 2215 days
#1 posted 06-11-2013 04:48 AM
I have been replacing popping nails in my deck for 15 years. I use deck screws available at the big box stores, they are corrosion resistant.
13623 posts in 3425 days
#2 posted 06-11-2013 04:50 AM
sound like you are on the right track
the screws to use are those star or square drive ones
they are harder than gold deck screws
and of course more expensive too
stay away from the square/philips head ones
they don’t work to good with either bit
not enough ‘meat’ there for either to do a good job
but the good thing with the better screw
is they have a bit in each box
that is just right for the head
View OnlyJustME's profile
OnlyJustME
1562 posts in 2461 days
#3 posted 06-11-2013 06:09 AM
Definitely pull and replace with screws.
I always use Deckmates and never had a problem. Just dont use the type made for composite wood. Smaller head design.
-- In the end, when your life flashes before your eyes, will you like what you see?
View scotsman9's profile
scotsman9
134 posts in 1973 days
#4 posted 06-11-2013 12:00 PM
I just put a porch on the back of my house and it contains zero nails, nadda one.
T25 and T20 star decking screws, expensive but worth it.
-- Just a man and his opinion.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3564 days
#5 posted 06-11-2013 12:49 PM
Yep, replace the nails with screws. You can buy deck screws at various lengths at the home stores that are coated and work great for decking.
-- Wayne - Plymouth MN
