What Is the Best Way To Get a Heavy Tool on a Mobile Base
Forum topic by DavidNJ posted 06-11-2013 12:32 AM 4495 views 0 times favorited 26 replies Add to Favorites Watch
View DavidNJ's profile
DavidNJ
389 posts in 2077 days
06-11-2013 12:32 AM
The drill press probably weighs close to 200#, the bandsaw close to 300#. They are in a basement, no engine hoists or blocks and tackle from the ceiling.
How do you get them on the mobile bases without damaging them or damaging the mobile bases?
26 replies so far
View kdc68's profile
kdc68
2680 posts in 2361 days
#1 posted 06-11-2013 12:41 AM
Don’t know what mobile base you have….but the last one I bought for my table saw had instructions on how to build the base around the tool….here’s the pdf….maybe this will help
http://www.grizzly.com/products/Heavy-Duty-Mobile-Base/D2057A
-- Measure "at least" twice and cut once
DavidNJ
#2 posted 06-11-2013 12:50 AM
I have two. The ShopFox D3757 which I want to put under the bandsaw:
And the Rockler which I want to put under the drill press:
View AandCstyle's profile
AandCstyle
3135 posts in 2341 days
#3 posted 06-11-2013 01:00 AM
Cut some blocks of wood shorter that the width of the opening in the mobile bases. Then tilt the tool up and slide a block under it. Then go to the opposite side and tilt the tool up and slide a block under that side. Repeat the process until the tool is high enough to clear the base. Assemble the base around the tool. Then tilt the tool and remove one block and set the tool on the base and, again repeat the process on the opposite side. You may need an assistant to insert and remove the blocks. HTH
-- Art
kdc68
#4 posted 06-11-2013 01:04 AM
Now that I see your mobile bases, the link of instructions I posted might not be applicable to your situation…Strong friends and cold beer might resolve this by lifting your bandsaw and drill press onto the assembled bases….good luck
AandCstyle…your advice is that of the link I posted
View RogerInColorado's profile
RogerInColorado
321 posts in 2038 days
#5 posted 06-11-2013 01:11 AM
For my drill press, I simply tipped it over (carefully!) onto the floor and then bolted the base and the drill press together. Once it was mounted, I just tipped it back up
DavidNJ
#6 posted 06-11-2013 01:17 AM
When I was 20 that would have worked. Now? I’m the only one on the block who mows their own lawn.
One of the bases goes under the unit. I’m thinking if I rock the saw on to blocks so it is higher than the base plus maybe 4”. The put the base wood on blocks with some wood on top of that and slide the band saw on to the wood over the base wood. Install the corners. The rock it one way then the other to remove the wood between it and the base. If the base is 4” off the ground I should be able to get an automotive floor jack under it to get it on the ground. The aluminum ones are light enough to get to the basement.
The drill press I could support with wood in the middle. Build the base around it. Then just rock it to remove the supports and drop it on the base.
I have no idea how I’m ever going to get a jointer into the basement. Maybe I should install some sort of pulley system on the rafters just for this purpose. I’m not sure there is enough room…it might have to be between the rafters. If I do that I might be able to use it to lift the cyclone on to a platform cart as discussed in the other thread: http://lumberjocks.com/topics/50577
AandCstyle
#7 posted 06-11-2013 01:34 AM
David, when I got my G0490X jointer the bed was in one long wooden crate. This was the heavy part. If yours is similar, I would think you could slide the crate down the stairs in a controlled manner, assuming it is a straight shot, then un-box it. I lifted it onto the base with a HF shop crane. I have used the crane many times so the cost isn’t all that bad, maybe you would be able to rent one someplace. FWIW
-- Art
DavidNJ
#8 posted 06-11-2013 01:34 AM
I could get this for $40 at HF:
I could drill a 1/2” hole through 2 rafters with a 1/2 rod and some extra blocks on the side to add strength. The bandsaw even has a hook on top.
View Loren's profile
10477 posts in 3732 days
#9 posted 06-11-2013 01:38 AM
Muscle. Steel toe boots.
Over 400 lb. hoists, wedges, prybars and so forth help.
View Buckethead's profile
Buckethead
3194 posts in 1953 days
#10 posted 06-11-2013 01:41 AM
If you are going to use framing members (joists/rafters) to support your shop tools, please remember to add temporary supports near your hoist. A 2×4 “T” brace (post) would make me feel a lot better about the lift.
-- Support woodworking hand models. Buy me a sawstop.
View Mainiac Matt 's profile (online now)
Mainiac Matt
8274 posts in 2413 days
#11 posted 06-11-2013 01:43 AM
If you have a lever long enough, you can move the world!
-- I yam what I yam and that's all what I yam
View SnowyRiver's profile
SnowyRiver
51457 posts in 3564 days
#12 posted 06-11-2013 02:12 AM
I have pretty much all my machines on mobile bases. I had the neighbors come over and we just lifted them up on the base. It went pretty easy with 3 of us.
-- Wayne - Plymouth MN
DavidNJ
#13 posted 06-11-2013 02:21 AM
Are your neighbors in their 20s or in their 50s?
It would be easier to reinforce the rafters with each other or a supplementary panel than a floor support…their just isn’t room.
I could use a joist supported by a lolly column as one of the joists.
SnowyRiver
#14 posted 06-11-2013 02:55 AM
If you are asking me, my neighbors are in their 60s and so am I. If the weight is too much then take it apart. On the drill press we just took the head off, put the stand on the base and lifted the head back on the stand. We did the bandsaw all in one piece, and we lifted my floor mortise machine in one piece on a base too. You only have to lift it a few inches.
13623 posts in 3425 days
#15 posted 06-11-2013 03:06 AM
if you tilt the tools
and put the bases under them
be careful when raising them back up
when the wheels on the base
come into play
it might want to ‘skate’ away from you
maybe put something on the floor
to keep the wheels from moving
and never lift the band saw by the table
it can break the trunnion
best of luck
