Ridgid R2401 Trim Router has Non-Universal Base
Forum topic by RonInOhio posted 06-09-2013 11:30 PM 7992 views 0 times favorited 7 replies Add to Favorites Watch
View RonInOhio's profile
RonInOhio
721 posts in 2857 days
06-09-2013 11:30 PM
Topic tags/keywords: router
Guess I should of done a little more due diligence on this trim router. I almost pulled the trigger
on the Makita Package for 239.00 on HD’s website. Maybe I will now.
Anyway, found out the base on this Ridgid router is non-standard and if you want to use a guide
bushing, you have to order the base for the previous model of this router the 2400. Really ?
So thats another 10.00 at least including shipping. I was a little dismayed also that there are little to no
after-market accessories for this router either. No plunge base particularly.
I have spent the better part of 4 days trying to rig my Rotozip up to cut mortises using a homemade template. I really don’t feel inclined to be doing a lot of fabricating on this Ridgid router to enable it to do something that should of been designed into the base.
So, a little disappointed and will probably return this unit and get either the Makita set that comes
with a plunge base, a stationary base and a tilt base. Plus edge guide, dust collection, and has a little more
power. Also considering the Dewalt trim router and plunge base.
Now that I have had my rant, just curious what owners of this router did for this obvious over-sight
by Ridgid engineers.
7 replies so far
View NiteWalker's profile
NiteWalker
2737 posts in 2570 days
#1 posted 06-09-2013 11:36 PM
Ron, it’s extremely easy to make your own in about 20 minutes.
That’s what I did.
RonInOhio
#2 posted 06-09-2013 11:38 PM
Did you use 1/4” acrylic or lexan ? I had some problems cutting the acrylic. How did you cut it without
it melting on you ?
RonInOhio
#3 posted 06-10-2013 01:00 AM
Actually the problem I had was that I had to drill a 2 1/2 inch hole in Plexiglass for my RotoZip.
That won’t be neccessary for this. The smaller holes go pretty easy with spade and regular drill bits.
View TorxNut's profile
TorxNut
58 posts in 1890 days
#4 posted 06-10-2013 01:36 AM
I ran into the same problem. I solved it two ways – one was by using the earlier Ridgid 2400 sub-base and the other was by swapping a PC sub-base onto it. Check http://www.woodworkingtalk.com/f12/ridgid-r2401-trim-router-question-30372/ and scroll to near the bottom.
The extra base costs you $10. That’s $99 for the Ridgid router + $10 for the base. I think you did okay. I’m pleased with my 2401.
Bill
RonInOhio
#5 posted 06-10-2013 01:59 AM
@Torxnut
Bill, are you saying that I have to order a PC sub-base as well as the 2400 sub-base ??
Why the PC sub-base ?
One of my local HD’s has the Makita trim router for 89.00. More powerful and has a universal
base as far as I know. I was tempted to go that route. Instead I went ahead and ordered the
2400 sub-base and some guides from Rockler.
Now, what about that PC sub-base ?
View MNgary's profile
MNgary
298 posts in 2410 days
#6 posted 06-10-2013 02:12 AM
The two bases that came with my DeWalt router have openings for 1-3/4 inch bushing sets instead of the PC/B&D standard of 1-3/16. I think many of the router tables use a 1-3/4 opening, too.
-- I dream of a world where a duck can cross the road and no one asks why.
TorxNut
#7 posted 06-10-2013 02:36 AM
Ron,
The PC base was just another inexpensive way of solving the same problem of getting bushings into the router base. The PC base is also a 1/2” bigger OD if you wanted a little more stability. You can see that in the pictures in the link I mentioned in the other post.
My plan was to use the trim router for cutting inlays. I figured the small router would be easier to handle with the delicate stuff.
Bill
