advice on where to find 5/8 arbor grinder buffing wheel
Forum topic by KDL posted 06-09-2013 08:21 PM 3935 views 0 times favorited 11 replies Add to Favorites Watch
View KDL's profile
KDL
36 posts in 3643 days
06-09-2013 08:21 PM
Topic tags/keywords: polish buffer wheel grinder
Hey Lumberites, I’ve got a Delta 8” variable-speed two-wheel grinder with 5/8 arbors. Currently it has one gray grinding wheel for rough work, and one friable white wheel for the lighter work. I’d like to add a stiff buffing wheel so I can polish/hone my blades. Unfortunately, but I’m having fits finding a buffing wheel with a 5/8 arbor. I did find one set of cloth wheels on ebay, but they were quite thin, and only one was likely to be stiff enough to matter. Suggestions? Possible source or better choice of wheel material for polishing?
Many thanks for reading and any suggestions,
Kurt
11 replies so far
View crank49's profile
crank49
4028 posts in 2847 days
#1 posted 06-10-2013 12:21 AM
In the jewelry industry we use buffs that have a pinhole in the buff and a tapered arbor adaptor. The adaptor slips over the threaded grinder spindle and is fixed in place with a set screw. The spindle taper is threaded in a spiral fashion so you turn on the motor and place the buff hole against the spindle and it just screws itself on. To change to a different buff you turn the motor off, hold the shaft and un-screw the old buff and then put another on just like before.
We have hundreds of special purpose buffs available to choose from. The best ones have leather or shellac reinforced centers and the one I especially like to use to lap steel edges is a chamois buff using chrome oxide green compound.
A good source for these materials is Rio Grande jeweler’s supply in Albuquerque, NM. Go to http://www.riogrande.com
and look up polishing supplies.
View JustJoe's profile
JustJoe
1554 posts in 1915 days
#2 posted 06-10-2013 12:26 AM
Like crank49 said. Here’s the tapered arbor adaptors. This one is made go to on the left side of the grinder, if you want to put the buffing wheel on the right then they have another one for that.
http://tinyurl.com/mhvm3gh
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View gfadvm's profile
gfadvm
14940 posts in 2566 days
#3 posted 06-10-2013 02:00 AM
I use those tapered spindles as well. Mine came from Wholesale Tool.
View sprucegum's profile
sprucegum
324 posts in 1874 days
#4 posted 06-10-2013 10:03 AM
I bought one of those cheap arbors on ebay several years ago and hooked a old motor to it. They are a pot metal frame with bronze bushings and a 1/2” arbor that way you can have a separate unit for buffing with 2 wheels loaded with different grit compound. Saves changing wheels and you won’t get much money in it.
-- A tube of calk and a gallon of paint will make a carpenter what he ain't
View KDL's profile
KDL
#5 posted 06-10-2013 06:24 PM
Thanks for the suggestions. For all my web surfing, I hadn’t come across those options. Looks like I can use an adaptor or get a pad with a 5/8 hole.
View teejk's profile
teejk
1215 posts in 2561 days
#6 posted 06-10-2013 06:52 PM
I think they are all 5/8ths arbors when you get to 6” and larger wheels (actually 1/2 wheels that allow you to knock out the bushing to convert to 5/8ths).
View lieutenantdan's profile
lieutenantdan
176 posts in 2182 days
#7 posted 06-10-2013 08:30 PM
You can buy a sleeve bearing (flanged or unflanged) from McMaster Carr. Lots of sizes and metal types.
-- "Of all the things I have lost in life, I miss my mind the most."
View hoosier0311's profile
hoosier0311
706 posts in 1902 days
#8 posted 06-11-2013 06:21 PM
maybe you could set this thing up. keep you from having to swap out wheels and pads.
http://www.harborfreight.com/garage-shop/stationary-grinder-buffer/6-inch-buffer-94393.html
-- atta boy Clarence!
View mchuray's profile
mchuray
81 posts in 2874 days
#9 posted 06-12-2013 07:52 PM
These folks will get what you need , but they can be slow.
Mark
http://www.pro-polishing-tools.com/Felt-Polishing-Wheels.html
View Tom Coster's profile
Tom Coster
120 posts in 2715 days
#10 posted 06-12-2013 08:07 PM
Thanks for the info on the tapered arbor. That is slick.
-- Tom, MI, SC
Tom Coster
#11 posted 06-12-2013 08:12 PM
I have the harbor freight set up at work that Hoosier mentions. It gets badly abused and has held up well.
-- Tom, MI, SC
