Need a shorter fence (crazy, I know)
Forum topic by Charlie_Papa posted 06-09-2013 11:50 AM 895 views 0 times favorited 3 replies Add to Favorites Watch
View Charlie_Papa's profile
Charlie_Papa
7 posts in 1752 days
06-09-2013 11:50 AM
Topic tags/keywords: need biesemeyer accu-fence
Hello everyone. I’m new here, and not sure this is the right forum to post this, but I found a Powermatic 66 table saw on craigslist and couldn’t pass it up. It has a 53” Accu-Fence and the little lady is flipping out about the size, as it’s in our shared-space drive-under basement/shop. I promised I would locate a shorter fence to use until we build a dedicated shop several years down the road. Two questions:
1. The Accu-Fence looks an awful lot like a Biesemeyer fence. Are they interchangeable? For instance, if I find some Biesemeyer fence rails, can I use the Accu-Fence T-square on them?
2. Would anyone here happened to have upgraded to a larger fence (the logical progression) and have some shorter fence rails collecting dust that I might be able to purchase?
I really appreciate any advice. I really think if she’ll use the larger fence a few times, she’ll find that a smaller one is unnecessary, but I have to make good on my word to find a shorter one.
Thanks.
CP
3 replies so far
View knotscott's profile
knotscott
7877 posts in 3283 days
#1 posted 06-09-2013 12:25 PM
The rails should be interchangeable with a Commercial Biese, Shop Fox Classic, Jet Xacta, HTC, and other commercial duty t-style fence rails. You can also cut down the long rails to something shorter, but it does seem a shame to cut them if you don’t have to. Another option is to buy steel tube stock from a steel supply house and drill and tap your own.
Shawn Masterson
1324 posts in 1856 days
#2 posted 06-09-2013 01:57 PM
I have a shop fox and it is a bastard size tube 2 3/8. Tell her to park outside. when I got mine it was for a 32” delta setup. I called about a new set of rails and they said it would be almost as much as buying another fence. I then called around to source a piece of tubing and being 2 3/8 no one had it. I had a friend bend me some L- shape steel and I very carefully welded it together making the size tube I needed. I say tell her to deal with it. The longer it bugs her, the sooner you my get your new shop.
Charlie_Papa
#3 posted 06-14-2013 05:29 AM
Well, I wish it were as simple as reasoning with her, but unfortunately… I’ve learned to pick my battles. I made a deal, so I’ll stick to it. I guess I’m going to order a whole Biesemeyer system from Grizzly. They seem to have the best price with the most reasonable shipping. Any chance someone has a coupon code they don’t plan to use? Anything helps! I appreciate all the input.
