Grizzly G0715P + Outfeed roller table
Forum topic by ampedup posted 06-09-2013 11:49 AM 4436 views 1 time favorited 9 replies Add to Favorites Watch
View ampedup's profile
ampedup
6 posts in 1724 days
06-09-2013 11:49 AM
After spending several months reading some excellent reviews from the different threads I thought I would join and try and give back. Calling myself a hobbies might be stretching the definition a bit but I enjoy the satisfaction of a finished project that has been built with my own two hands.
After using a very small Craftsman contractor saw for many years and as my projects became larger, I decided I needed to upgrade. The upgrade was not only to improve the functionality of the saw but for safety reasons as well. Pushing larger stock on such a small table will quickly cause you to pause and start counting fingers. This also helped selling the financial advisor (aka the wife) on the purchase as well.
Once I knew what saw would fit my current needs and budget (Grizzly G0715P) I spent the next several months (ok more like 6+ months) researching and reading every bit of information regarding the saw and its competition. That is how I stumbled across the forum and the wealth of information it provided.
With all that being said, I want to give back to the forum as my way of saying thanks for all the great information and by doing so, hope someone else might benefit from the information I’ve provided.
One of the main requirements I had for the saw was the ability to add an outfeed table that would fold out of the way when not in use (working in a two car garage and not willing to give up any parking space). During my research, I didn’t find anyone using such a table with this particular saw. However, I wasn’t to alarmed, I just figured everyone (but me) was blessed with great woodworking skills and could make beautiful outfeed tables that would trump anything mass produced. It wouldn’t be until months later I would uncover the actual truth.
The day finally came for me to place my long awaited order with Grizzly but before doing so, I wanted to be reassured the HTC H8875 26” outfeed table would work with the G0715P hybrid saw. Although this statement wasn’t a lie, it wasn’t the complete truth either. My saw arrived on a Friday and I quickly got busying getting it all set up. Saturday morning I stepped into the garage fully expecting to finish up by installing the outfeed table. However, it became quite obvious that the mount provided wasn’t going to just “mount” to the back of the saw as I originally envisioned. Deciding not to get my engineering degree during my college years I decided it might be best to call Grizzly just in case I was misreading the instructions. Customer service explained that I would need to speak to tech support but they wouldn’t be open again until the following Monday. Monday finally came, took forever while my shiny new saw was just begging to be used, and I was on the phone first thing with tech support. The gentleman quickly confirmed what I was dreading to hear. Yes people, it’s true…the HTC H8875 outfeed table won’t work on the Grizzly G0715P table saw without MODIFICATION.
I absolutely hate returning things but here I was with a $260 table that couldn’t be used in its current condition. Do I dare start hacking it up in hopes that I can make it work or do I just settle for the fact that it just won’t work? A few days searching the internet for options, taking measurements and speaking to people that claim to have a little knowledge of structural integrity. I decided the best option was to grab my side grinder and a new cut-off wheel and hope for the best.
Here is the problem created with the G0715P
You can see how the factory mount has a small void to fit some saws but not quite big enough to fit the space needed for the G0715P
The good thing about the mount is you have just enough room to cut out the excess metal between the two support beams.
It’s important you center the templet with the box on the back of the saw cabinet so you will have the proper clearance to mount the base.
Test fit to make sure the base will clear the box. If you’ve measured and cut everything right, the mount should snuggly fit the sides of the box. I also left the templet in place for the test fit to make sure my holes lined up. Minor adjustments to the templet might be needed to get everything aligned as needed. It’s important to take your time here as the holes you drill for the top mount is very important to the final position of the table
Now some might notice that we have cut away a section of the base the incorporated two of the six mounting locations. This is where my own ideas and confirming with people with some engineering knowledge comes into play. I too, was worried about the implications caused my cutting away the two mounts. To remedy this issue, I purchased 2” x 1/8” thick flat sock to use as internal bracing for the mount.
and after a little paint to make it look nice
By mimicking the vertical mounting locations of the table mount I was able to transfer that information to the flat stock and tie the top and bottom mounts from inside the saw cabinet. I had to trim the top corner of one mount and the bottom corner of the other mount to get them to sit flush to the back of the cabinet.
Table installed and appears to be structurally as strong as the original mount . The only negative side effect in encountered from this modification is the time it took to get everything squared up and level with the table saw top. With the original mount, the 4 upper mounts are what helps with leveling. this is why making sure the top “two” holes are perfectly parallel with the table is very important so please take your time.
Need to add a few more things to the saw and I’ll have it set and ready to go.
9 replies so far
View toolie's profile
toolie
2109 posts in 2538 days
#1 posted 06-09-2013 12:16 PM
links don’t appear to be working.
ampedup
#2 posted 06-09-2013 02:24 PM
Let me work on them and see if I can get them to work
toolie
#3 posted 06-09-2013 05:31 PM
nicely done. perhaps other 715, 4512 or 21833 owners will find the techniques used in fabricating this outfeed table helpful in fitting OTs to these similar saws.
View MashMaster's profile
MashMaster
125 posts in 2569 days
#4 posted 08-09-2013 07:30 PM
I have a 715 and would love to get this to work. I’m confused as to where you put the sheet metal brackets.
-- - Dave ; Austin, TX
ampedup
#5 posted 08-09-2013 10:29 PM
They run vertical between the top and bottom support bracket for the table. They are mounted inside the saw cabnet, see picture 9. If you still need help, I’ll be happy to see if I can get a better picture.
BTW…no issues at all with the current setup.
MashMaster
#6 posted 08-10-2013 12:48 AM
Ah I see it now. thanks
Do you find it worthwhile having the out feed table?
ampedup
#7 posted 08-10-2013 05:16 PM
Absolutely…I use it almost every time I make a cut. I also love how it will fold down out of the way when not in use. If I had a larger shop and/or a perminet spot for my saw and a stand alone table it might not have been a necessity. I pushed a 1/2 sheet of 3/4” MDF through it yesterday and didn’t have an issue at all. I would have never tried that with my old setup.
View copcarcollector's profile
copcarcollector
256 posts in 2027 days
#8 posted 08-10-2013 05:54 PM
Great problem solving!
I have the larger 3 roller wide version on my Grizzly 0691 table saw, I find that pieces pushed through often roll right off the outfeed table and on to the floor! So I put a clamp on the end to stop the piece, guess I have too much downhill slope on the back end!
ampedup
#9 posted 08-10-2013 11:00 PM
I know you have ability to make some minor adjustments to correct this problem on the table such as mine. However, maybe a few shims under the lower mounting bolts could also help with your current issue?
