Design help-Attaching hardwood to plywood
Forum topic by Rxmpo posted 06-09-2013 04:18 AM 1001 views 1 time favorited 8 replies Add to Favorites Watch
View Rxmpo's profile
Rxmpo
268 posts in 3979 days
06-09-2013 04:18 AM
Topic tags/keywords: question cherry
Hi All,
I am in the process of designing a bed for a friend who lives in a small apartment in Manhattan. I tell you this part because setup and breakdown of the bed will be critical for now and for the future when he moves. So I have designed a platform type bed that will be able to be broken down into four main parts (no including slats and center brace). The width of the sides will be 8”.
The thought is to make the internal structure using plywood like a honeycomb and attaching hardwood to the outside of the plywood structures. The top, bottom both sides will each come apart and can be assembled on site. Hardwood will then be added on top of each side and attached, covering the plywood bases. Bookshelf will be added at the head of the bed but not a concern.
My concern and question is about how to go about attaching the hardwood (cherry) around the outside of the frame? I have thought about milling the exterior down to make a thin exterior and gluing it on but concerned about it warping. I thought about keeping the cherry at 3/4’ thickness and screwing in on from the plywood side but not sure. So, I thought I would ask the audience here for their thoughts and ideas about the best way to proceed?
Thanks for the help in advance!
8 replies so far
View PaulLL's profile
PaulLL
160 posts in 2210 days
#1 posted 06-09-2013 04:41 AM
That looks like it’ll turn out to be a really nice bed. I would probably glue and screw from the inside. screws should hold it even I believe.
View Lee Barker's profile
Lee Barker
2170 posts in 3084 days
#2 posted 06-09-2013 04:42 AM
I’d keep the cherry at 3/4, Rxmpo.
I’d be inclined to keep it as the outside of the box. You could pocket screw the dividers to it, then screw the inside wall to the dividers. Lighter, easier to handle, just as strong.
If you’re looking for some spiffy fasteners to hold this all together, I’d suggest you study the Hafele catalog.
I like the design. This would make an interesting LJ blog. Go for it!
Kindly,
PaulLL
#3 posted 06-09-2013 04:43 AM
Just had a thought looking at the honeycomb, you could hinge the top cherry pieces and line some of those to make extra storage spaces.
View Lenny's profile
Lenny
1616 posts in 3761 days
#4 posted 06-09-2013 04:22 PM
Hi Mike,
First, I really like your concept…it’s pretty ingenious. I’m also jealous of your Sketchup skills. As I can’t come up with any suggestions, I say go with the 3/4” thickness and screws from the inside. LeeBarker’s idea to use the cherry as the outside of the box will save some material and labor. Good luck.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
View redSLED's profile
redSLED
790 posts in 2126 days
#5 posted 06-09-2013 06:40 PM
Good looking design.
Looks to me if the main 4 joints are to be screwed together somehow, the owner will need a right angle drill/driver to assembly/disassemble, unless they have one of the newest brushlesss shorter-than-usual cordless drill/drivers.
Rxmpo
#6 posted 06-10-2013 02:49 AM
Thanks all, for advice and comments about design.
Lenny, the Sketchup learning curve was steep, but truly worth the effort as it saves time and money making your mistake on the monitor and not in the shop. A full scale drawing is still the best imo when possible because hard for me to envision size and scale with modeling.
I like the hinged sides idea Paul, that has me thinking… Plus could help eliminate the issues Red brought up, which I had already been wracking my brain over…
As usual, great help…
Thanks!
View Radu's profile
Radu
330 posts in 3277 days
#7 posted 06-10-2013 03:06 AM
Would anything like these help?
or
Rxmpo
#8 posted 06-10-2013 05:10 AM
Interesting Radu… Never seen these before. Thanks.
