looking for a good but cheap new thickness planer, any thoughts on this delta?
Forum topic by michaelsgarage posted 06-08-2013 05:30 AM 15237 views 0 times favorited 22 replies Add to Favorites Watch
View michaelsgarage's profile
michaelsgarage
71 posts in 1892 days
06-08-2013 05:30 AM
Topic tags/keywords: delta thickness planer planer
22 replies so far
View NormG's profile
NormG
5955 posts in 2970 days
#1 posted 06-08-2013 05:52 AM
Dewalt 734 or 735. 734 is the only thickness planer I have owned, it does a wonderful job
-- Norman - I never never make a mistake, I just change the design.
View NiteWalker's profile
NiteWalker
2736 posts in 2543 days
#2 posted 06-08-2013 11:33 AM
If you’re ok with cutting the ends off of sniped boards, the delta will be ok. Otherwise, look at the dewalt 734 or the ridgid.
View YanktonSD's profile
YanktonSD
190 posts in 2498 days
#3 posted 06-08-2013 11:45 AM
I have an old Ryobi AP-10 It is great but like most planers has some snipe at the ends butif you set it up right you have no snipe. But starting out If you can find a used AP-10 you can’t go wrong.
View Tennessee's profile
Tennessee
2861 posts in 2480 days
#4 posted 06-08-2013 12:41 PM
Agree with Nitewalker. I own an old Rigid from 2000 that I used up until last year when I finally bought a spiralhead 15” unit.
For my money, the Rigid has slightly less bells and whistles than the DeWalt, but I think, like mine, the blades can be resharpened and are double sided. Over a period of years, that pays for itself many times over. And both the Rigid and Dewalt can be easily setup to not snipe.
View toolie's profile
toolie
2120 posts in 2594 days
#5 posted 06-08-2013 12:46 PM
the ridgid 4330 was rated top value bench top planer when wood magazine last compared 13” planers. the newer 4331 is improved, with a head lock. coupled with the 90 day satisfaction guaranty, the 3 year new tool warranty and the LSA, make it a compelling choice. find a HD that will honor harbor freight’s “20% of any single item” coupon, making the $400 planer available for $320, and it appears to fit your “good but cheap new thickness planer” criteria.
View NoLongerHere's profile
NoLongerHere
893 posts in 2642 days
#6 posted 06-08-2013 12:57 PM
I own and use the Delta 22-580 13” Planer on a regular bases and couldn’t be happier.
As much wood as I have put through this, I probably should have bought a big 3 phase 15” planer but I don’t have the room and I can take this one to the jobsite if needed.
No snipe with the side locking handle… well, almost no snipe. I don’t think any planer can guarantee that 100% of the time. That’s why most shops cut their stock long. You can have snipe and not see it until the stain goes on.
It folds up and stores the cord and can be carried very easily with two hand grab positions, high and low. This is a big deal if you move it a lot.
2 speed feature is awesome although I use it on the slower speed 90% of the time.
The dust port (not included) has a 4” exhaust pipe on the right which isn’t the best but it works fine – just smack it if it gets a little clogged. ha!
The blades are easy to install and have two carbide sides. The only drawback might be the star screws eventually want to stick and, if you’re not careful you might bust your tool or strip the head. I don’t know why they don’t just use regular bolt heads. I wonder if anti seize would be a good idea?
I hear the Dewalt is pretty good too – big fan of Dewalt.
But, that Delta you are looking at is the bottom rung of Chinese made planers. Spend a little more and you won’t be sorry. Isn’t that always the case?
Tennessee
#7 posted 06-08-2013 01:02 PM
Nothing like solid support for all the brands, when it is all said and done, huh?
Seems like whatever you pick, you’ll do well.
View TorxNut's profile
TorxNut
58 posts in 1863 days
#8 posted 06-08-2013 02:40 PM
I have a DeWalt 733 that I’ve been very happy with. I’ve heard good things about the Ridgid but also the Steel City seems to have a good reputation.
Bill
View helluvawreck's profile
helluvawreck
30765 posts in 2833 days
#9 posted 06-08-2013 02:45 PM
I like the Dewalt 735.
helluvawreck aka Charles
View knotscott's profile
knotscott
7980 posts in 3341 days
#10 posted 06-08-2013 03:36 PM
The TP305 has no snipe control, and isn’t all that cheap. The DeWalt DW735 is only $459….much better value IMHO. If you’ve got to go bare bones (like the TP305), the Craftex CT179 is $299, saving you $85 over the TP305. The Craftex is pretty much the same planer as the Grizzly G0505. You can always check your local HD for the Ridgid R4331 too.
Tennessee
#11 posted 06-08-2013 07:33 PM
After running my Rigid into the dirt for over ten years, planing wood like leftover 140 year old oak, multiple hardwoods down to 1/8” and many other stupid jobs that should have killed it, I have to whole heartedly endorse the Rigid.
View bbc557ci's profile
bbc557ci
595 posts in 2040 days
#12 posted 06-08-2013 07:43 PM
Seems to be plenty of well liked hobbyist/small shop class planers out there. Kind’a like a Ford VS Chevy thing LOL.
I’ve been putting a Dewalt 735 to use for a couple of months now and have nothing to gripe about.
-- Bill, central NY...no where near the "big apple"
View Lector's profile
Lector
7 posts in 1912 days
#13 posted 06-08-2013 10:24 PM
Good & Cheap ?? Only if you get lucky @ a garage sale or an Auction.
-- Mistakes are good,learning how to fix them is better.
View teejk's profile
teejk
1215 posts in 2650 days
#14 posted 06-08-2013 10:59 PM
Reedwood…Delta 22-580 13” Planer and “almost no snipe” made me laugh. I’ve owned one for years and gave up trying to fine-tune it to minimize “snipe” (I think it’s a function of the pressed steel tables that make it a portable). Somebody recently tested all the portables and concluded that there was no such thing as a “snipe-free” machine. I have learned to deal with it however using shallower passes and supporting the outfeed. The 22-580 does have the 2 speed box (which I rarely bother with) but also has the cutter-head lock which has become standard now I think other than the machine the OP is looking at. That IMHO is critical on any of the machines.
NoLongerHere
#15 posted 06-09-2013 12:58 AM
yea, that’s like, almost square. or…
Almost on time…
Almost finished and got paid…
almost never cheated…
almost no dust… I may have started something.
I do the same thing, give the table a little lift on short pieces or walk around and lift long pieces up a bit at the end. That, and a 1/4 turn on the final pass and I get good results.
all good stuff
