8/4 walnut and cherry between 7 - 9% moisture
Forum topic by yellowtruck75 posted 06-07-2013 01:07 AM 996 views 0 times favorited 5 replies Add to Favorites Watch
View yellowtruck75's profile
yellowtruck75
469 posts in 3089 days
06-07-2013 01:07 AM
I have a bunch of 8/4 walnut and cherry live edge slabs air drying with 7 – 9% moisture. The walnut has been stickered for ~18 months and the cherry has been stickered ~12 months. What moisture level would be desirable for 8/4 walnut and cherry?
5 replies so far
View richardwootton's profile
richardwootton
1699 posts in 1977 days
#1 posted 06-07-2013 01:30 AM
Is that the MC at the surface or have you cut a piece off to see if the center MC is roughly the same?
-- Richard, Hot Springs, Ar -- Galoot In Training
yellowtruck75
#2 posted 06-07-2013 03:45 PM
This is the MC from the surface of serveral different pieces throughout the pile.
View jordanp's profile
jordanp
1086 posts in 1962 days
#3 posted 06-07-2013 04:47 PM
I would have a hard time cutting a piece of 8/4 walnut or cherry at random unless I knew i needed that cut in the future, But from what i’ve seen and been told that is the best way to check the MC on drying wood.
-- J. Palmer Woodworks - Rockwall TX -I woke up this morning thinking “man, I really hope someone posted some soul scarring sh*t on LJs today.” -- - Billy
View Post_Oakie's profile
Post_Oakie
84 posts in 2175 days
#4 posted 06-07-2013 05:34 PM
Desired moisture content depends on how you plan to use it. In extremely dry climates, you might want to go down to 6%, but generally 8% is accepted. A good pin moisture meter should give you a good idea of the moisture content. For thicker pieces, I drive a pair of nails half way into the wood, and use them for moisture probes. What temperature did you reach while drying? You need to hold at least 140 degrees to kill any bugs—especially since you are dealing with live edges.
-- Good judgement comes from experience. Experience comes from bad judgement.
View pintodeluxe's profile
pintodeluxe
5701 posts in 2835 days
#5 posted 06-07-2013 05:51 PM
Cut a couple inches off the end, and test the m.c. again.
You might get numbers between 12-15%.
For indoor furniture 6-8% is ideal, more or less.
If you can enclose the lumber, a home dehumidifier, a heater, and some fans will bring the m.c. down in a couple weeks.
