Starrett WoodPeckersXF BandSaw Blades - Info
Forum topic by steve posted 06-06-2013 01:46 AM 2679 views 0 times favorited 17 replies Add to Favorites Watch
View steve's profile
steve
363 posts in 2227 days
06-06-2013 01:46 AM
Does anyone use Starrett Blades in their Bandsaw?
I have a Rikon 14”
Never tried a Starrett bandsaw blade, have you? Do you recommend?
http://www.starrett.com/saws/saws-hand-tool-products/band-saw-blades
-- steve/USA
17 replies so far
View JollyGreen67's profile
JollyGreen67
1676 posts in 2997 days
#1 posted 06-06-2013 04:06 PM
Starrett is ok. I normally use Olson Pro, or Timberwolf, as I believe them to better than Starrett.
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
steve
#2 posted 06-06-2013 09:34 PM
I use 2 TimberWolfs now…the 3/4” 3TPI and a 1/4”, Both by PS Wood, I have absolutly no complaints with the Timberwolf/PS Wood blades…also I have the 5/8” that my Rikon 10-325 came with…I was just looking around and saw the Starretts
-- steve/USA
View MrRon's profile
MrRon
5258 posts in 3477 days
#3 posted 06-07-2013 04:32 PM
I use a Starrett 105” long 3T pitch blade for resawing. Great blade and a good price. The weld is practically invisible. You need a microscope to find where it is welded. As far as cut is concerned, it is just as good as the Timberwolf or Olsen blades.
steve
#4 posted 06-07-2013 11:10 PM
Thanks MrRon
-- steve/USA
JollyGreen67
#5 posted 06-08-2013 12:26 AM
I must’ve gotten a “second hand” Starrett. Maybe I’ll try again.
View lew's profile
lew
12495 posts in 3989 days
#6 posted 06-08-2013 02:57 AM
For resawing, you cannot beat Highland Woodworking’s Wood Slicer blade.
View fussy's profile
fussy
980 posts in 3285 days
#7 posted 06-09-2013 01:09 AM
I go along with Mr. Ron. I have been using Starrett for years. I get them from B. C. Saw in Toronto. Price, service,shipping and blades are first class. If It’s good enough for Michael Fortune or Mr. Ron, it’s good enough for me.
Steve
steve
#8 posted 06-09-2013 02:11 AM
thanks
-- steve/USA
View Surfside's profile
Surfside
3389 posts in 2407 days
#9 posted 06-18-2013 06:50 PM
For just woodcutting, I used haltbar band saw blades. Resawing , I used Lennox and Highland woodworking.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
MrRon
#10 posted 06-18-2013 10:43 PM
Who is Michael Fortune?
View Matt Rogers's profile
Matt Rogers
110 posts in 2204 days
#11 posted 06-19-2013 02:18 AM
I recently got a 1” Lenox Woodmaster Carbide blade for resawing and it is both expensive and good. Very smooth cut, very thin kerf, and very sharp. I also got a 1” Woodmaster B (for Bimetal) blade for resawing reclaimed lumber and dirty wood that may contain metal since I did not want to ruin the $120 carbide blade. The 1/4” Woodmaster B that I use for curved work has been holding up well after cutting out 300 chair parts out of black locust, white oak, and ash. Not an easy task for a blade.
All three have been much better than standard steel blades and I think worth the extra money.
-- Matt Rogers, http://www.cleanairwoodworks.com and http://www.cleanairyurts.com
Matt Rogers
#12 posted 06-19-2013 02:27 AM
I just checked out the Starrett site and looking at their blades, they are actually exciting. As far as I know, the limitation to most bandsaws in the smaller sizes is blade thickness, not width as the small wheels will stress the thicker bands and cause them to break. This combined with lower tension.
However, the Starrett blades are available in very thin sizes for each width. For example, the Lenox Woodmaster B blade is only available in 0.035” thickness for a 1” blade, but the Starrett is available in 0.023-0.035 thicknesses. The thin blade would require less tension and have a longer fatigue life on smaller bandsaws, while still have a greater beam strength than a narrower 3/4” or 1/2” blade that is 0.030 or 0.035 thick.
I think that i may try out their thin blades as my next purchase.
Surfside
#13 posted 06-19-2013 06:55 PM
Michael Fortune is a band saw master, furniture maker and a writer. He has many videos and articles about band saw applications.
steve
#14 posted 06-19-2013 08:58 PM
Matt,
I have a Rikon 14” Deluxe, it states that the widest blade is to be a 3/4”, but I see plenty room on the wheels and I have Carter guides which will set back enough to accomadate…could I …use a Starrett in 1” if the thickness is in the thinner range? What are ur thoughts on this
-- steve/USA
View Bill White's profile
Bill White
5148 posts in 4194 days
#15 posted 06-19-2013 10:59 PM
I don’t use any blade wider than 1/2” on a 14” BS. Tension requirements just don’t work well for blades over that.
Why do you feel that a wider blade will be better?
Not a smart a$$ question, just wonderin’.
Bill
-- bill@magraphics.us
