Forum topic by redwoods | posted 06-05-2013 04:12 PM | 2801 views | 0 times favorited | 3 replies | ![]() |
Does anyone have experience using a Performax SuperMax 25 inch dual drum sander and a preJet 16-32 and have any insights if the Performax SuperMax 25 dual drum sander is noticeably better? I have an opportunity to get a little used Performax SuperMax 25 dual drum sander for $1000, maybe less. Thanks |
3 replies so far
#1 posted 06-05-2013 04:17 PM |
2 drums is going to outperform 1 drum and a sander You will still have to fuss with the paper tension and |
#2 posted 06-05-2013 04:31 PM |
if its in good shape get it, I have the bigger performax models, and they are super |
#3 posted 06-05-2013 09:29 PM |
properly set up a super max 25×2 is a superior machine. It can be used for dimensioning lumber the same a planer just not as fast. Parts for repair are readily available. The major things to look at are : main motor should be a 5hp, and the speed controler / feed motor. The 5hp can be bought anywhere, but the controler/feed motor are over $600 if they need replaced, and can only be bought through performax. I needed a feed motor for the one I had so I called leason and they refused to sell me a replacement. They said they had them, but it could only be bought through performax. also it has a bastard spline so it has to be their parts. My solution was to have my neighbor rebuild it for me. I end up selling it because it took a large footprint 4’x4’. If you are in need it is a great machine to have. |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1371 |
Finishing
4908 |
6697 |
28070 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1420 |
Wood & Lumber
6234 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
