Cleats made out of wood
Forum topic by sgv posted 06-04-2013 10:26 PM 1168 views 0 times favorited 9 replies Add to Favorites Watch
View sgv's profile
sgv
266 posts in 1890 days
06-04-2013 10:26 PM
I am thinking about hanging my cabinets and drill press, grinder,ect with cleats, my question is how large do they have to be? will 1×2 cut at a forty five work? I have seen this before but cant find sizes any where on line. thickens to weight ?
as always thanks LJs
-- Tite Lines, May the wind be at your back
9 replies so far
View Hoakie's profile
Hoakie
306 posts in 4034 days
#1 posted 06-04-2013 10:39 PM
If you view my shop tour you can see my cleat system. I cut 8’ x 3” strips out of 3/4” plywood. I have had no problem hanging anything on them. For really heavy stuff (lathe tool cabinet) I utilize two rows of cleat.
-- John H. [To invent, you need a good imagination and a pile of junk. ~Edison]
View sgv's profile
sgv
#2 posted 06-04-2013 10:46 PM
Thanks Hoakie nice shop (hoakie, Va tec fan?)
Hoakie
#3 posted 06-04-2013 10:51 PM
Nah, play on my last name :)
View Buckethead's profile
Buckethead
3194 posts in 1867 days
#4 posted 06-05-2013 01:33 AM
I hang some pretty heavy stuff on cleats. Mdf ripped to 3.5” will hold a considerable amount. Plywood is probably better. Connect the cleats securely, and you’ll have no problem. When in doubt, max it out.
-- Support woodworking hand models. Buy me a sawstop.
View toolie's profile
toolie
2121 posts in 2627 days
#5 posted 06-05-2013 02:12 AM
3/4” plywood beveled at 45°. holds whatever i want to hang.
View sgv's profile
sgv
#6 posted 06-05-2013 10:52 AM
Thanks to all LJs has any one put a grinder on a cleat ? does it shake the wall to much?
View kdc68's profile
kdc68
2657 posts in 2275 days
#7 posted 06-05-2013 11:08 AM
One thing to add to the above comments would be to attach your wall cleats to structure (framing)....use long enough screws, lags, or whatever that will go through the cleat and the wall board or drywall, and get a good bite into the framing…..or if your walls are masonry or block get heavy duty anchors rated high enough plus some for what you think you need….don’t skimp
-- Measure "at least" twice and cut once
View sgv's profile
sgv
#8 posted 06-05-2013 11:30 AM
thanks kdc68 going directly into metal studs 2×6 that are attached to basement walls ( thats the way my builder does it)
View Fresch's profile
Fresch
229 posts in 1919 days
#9 posted 06-05-2013 12:39 PM
Thanks, I too had this question as I try to fit in a 12×16 shop.
