Craftsman Shaper Model 113.23920
Forum topic by PrimeRibAndADew posted 06-04-2013 06:30 PM 4959 views 0 times favorited 7 replies Add to Favorites Watch
View PrimeRibAndADew's profile
PrimeRibAndADew
3 posts in 2053 days
06-04-2013 06:30 PM
Topic tags/keywords: craftsman shaper
A friend of mine said, “I have a shaper I’ll never use again, (he is n his 80s) would you like it?” I said “sure, how much?” He said free, my favorite price. So I now have an old craftsman shaper in excellent condition but no manual and only one cutter. Hmmm. I believe the cutters are 1/2” bore. I have a few questions. Does anyone know where I can find cutters? Do I need to stick with Craftsman cutters or will I be able to use other manufacturers cutters? Does anyone have any insight to share about this particular shaper?
-- Life is like a peice of wood, you can complain about the knots or you can make them beautiful.
7 replies so far
View elm's profile
elm
16 posts in 1742 days
#1 posted 07-26-2013 12:37 AM
Gee… The very model shaper I am trying to resolve the mystery of the missing lock stud and associated parts and how to properly install them.
You can find the manual at vintagemachinery.org.
View Woodmaster1's profile
Woodmaster1
918 posts in 2551 days
#2 posted 07-26-2013 12:50 AM
You can get cutters from a variety of venders. You can get bushings so 3/4 cutters can be used. Mcls woodworking is one place to check.
View Handtooler's profile
Handtooler
1541 posts in 2096 days
#3 posted 07-27-2013 01:25 PM
I have the Craftsman 113-239291 which is the same unit as the 239201 including the steel legs, purchased in late 1970’s. I purchased 6 different cutters and a multiple sized bearing/coller set. The cutters were only HSS and didn’t stay sharp well at all when used on hardwoods. They were only available on special order and were discontinued sometime in the 80;s or early 90’s. Additionally, I added a reverseable switch so I can feed work from either direction and install the cutters from either side, top or bottom down. Woodmaster1 is correct in that MLCS (not Mcls) carries several most with 3/4” bore and 1/2” shaft reducer bearing. I haven’t purchased any for fear the 1/2hp motor would not eaisly operate the heavier larger sized cutters; rail and style set or panel cutters I’d really like to have.
Woodmaster1, What say ye about using the larger cutters on our machines, MLCS customer service didn;t answer me and I haven’t talked with Tech Support?
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Planeman40's profile
Planeman40
1151 posts in 2725 days
#4 posted 07-27-2013 08:21 PM
I have that shaper in my shop, bought it new in the mid 1970s. Works well. Cutters can be had from Grizzly (www.grizzly.com), look under shaper cutters. All the cutters now days are carbide. You DO need a reversing switch if you are going to use cutters that can be flipped upside down on the spindle. You have to run the work in the opposite direction. I should note that this type of home shop shaper has given way to electric routers that now have the power to handle large cutters whereas they didn’t until recently. As you got it for FREE, it shouldn’t bother you to spend a little money on the cutters for it. Quite a bargain!
Planeman
P.S. I would love to know the recommended cutter speed for this thing. Years ago I just estimated when I was sizing up the motor and pulleys. What I have works, but I would still like to know.
Handtooler
#5 posted 07-27-2013 10:25 PM
Thanks Planeman40. Do you use any large diameter heavy cutters sucessfully? I have drop leaf table set rabeting cutter glue joint etc which are all 1/2” bore and only about 11/2-2’ diameter.
View kimballd's profile
kimballd
26 posts in 1728 days
#6 posted 07-28-2013 02:18 AM
Here is an ebay link, lots of new and used cutters
http://www.ebay.com/sch/i.html?_sop=1&_lncat=0&_sacat=0&_from=R40&_nkw=shaper+cutters&_ipg=200&rt=nc
Here is a link to Oella Saw & Tool, Dan there is very knowlegable and helpful. Sells lots of new and used cutters and also sharpens them
http://stores.ebay.com/Oella-Saw-and-Tool?_trksid=p2047675.l2563
good luck
Woodmaster1
#7 posted 07-28-2013 03:32 AM
I have used 3/4” cutters with bushings and it worked fine on the craftsman shaper at school. I have also used a 1 3/4 hp PC router to cut raised panels at home and had no problems.
