Found at "Habitat 4 Humanity".. what is it? How you do dat?
Forum topic by poopiekat posted 06-04-2013 05:02 PM 1523 views 1 time favorited 23 replies Add to Favorites Watch
View poopiekat's profile
poopiekat
4349 posts in 3698 days
06-04-2013 05:02 PM
Topic tags/keywords: mdf glossy finish paint ignorenwbusa question
I bought some cabinet parts, approx. 24” X30” of a very unusual material. They appear to be MDF, 3/4” for commercial fixtures, with the most beautiful glossy red paint finish you could ever imagine! They actually look like painted steel panels. I’ve never seen such a high level of gloss on MDF, but it is giving me all kinds of ideas.
So how does one achieve an almost automotive-grade mirror-like finish on MDF? I assume there’s lots of sealing and sanding required, but does anyone know what technique, what equipment, what finishing materials are needed for an ultra-glossy color finish on MDF? I went back to H4H for more, it was all gone…
23 replies so far
View bandit571's profile
bandit571
19718 posts in 2647 days
#1 posted 06-04-2013 05:09 PM
Might be a MD…..O? Medium Denseity OVERLAY? A thin layer of paper is added to the MDF. Used a lot in road signs, and the New Yankee workshop for painted projects.
poopiekat
#2 posted 06-04-2013 05:19 PM
Possibly, bandit! I used to keep a couple of sheets in my shop for a local signpainter, she’d buy the sheets and store them at my place, she’d tell me what dimensions for a piece she needed for her custom orders. Mostly, I have no idea what paint products and techniques are required for such a slick surface. It’s almost mirror-like!
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2036 days
#3 posted 06-04-2013 05:39 PM
2 part reactive varnish in the hands of an expert can get the finish you describe very well on many surfaces. Especially high quality mdf, which is quit flat to start with, likely less sanding and more care in construction. Is very durable as well.
-- Who is John Galt?
View DS's profile
DS
2894 posts in 2384 days
#4 posted 06-04-2013 05:54 PM
I’ve done this a few times. It’s a PIA, but doable.
Surface preperation is critical.
At least 2 good primer coats make all the difference. No coarse scratches allowed.
Sand to 600 grit in primer. Then color coat, 600 grit again, then clear coats. By the third clear coat I am up to 2500 grit
The fourth and final coat of clear gets 5000, 8000 then 12500 grit and poilishing compound.
EDIT: I used precat lacquer.
View DS's profile
DS
#5 posted 06-04-2013 06:01 PM
Recent project in MDF
View LakeLover's profile
LakeLover
283 posts in 1903 days
#6 posted 06-04-2013 06:16 PM
We were in a fancy kitchen appliance store a couple years ago. My wife noticed these doors on a cabinet. They were flat with a slight radiused edge. Had a gloss blue coat and looked great.
She asked me how they were made. I said ” Looks like MFD, painted in an autobody shop.” A salesman over heard this and said to me. ” many people have asked, you are the only one that knew” I got a bit of a laugh out of that.
View DS's profile
DS
#7 posted 06-04-2013 06:19 PM
You can use automotive paint, but it is 5 times as expensive and much more volatile.
(I paid aprox. $40/gal for gloss precat while automotive is about $200/gall)
poopiekat
#8 posted 06-04-2013 06:35 PM
Hey, thanks everyone for some great advice and insight!
Though I hate to walk into paint stores, it looks like I will need a salesperson with some strong knowledge of his/her products to show me exactly which product will achieve the desired finish. The gloss ‘pre-cat’ sounds like the way to go. I have a few mdf projects just over the horizon, and I really like the slick, wet look of these new coatings. Thanks again for the great info, everybody!
p.s. Great looking console, DS!
View MrRon's profile
MrRon
4710 posts in 3207 days
#9 posted 06-04-2013 09:54 PM
MDO is not MDF. It is a plywood that is impregnated witha 30% polyester resin. It is used mainly for highway signs. It is waterproof and very stable. It doesn’t sound like what you have.
View KnickKnack's profile
KnickKnack
1088 posts in 3530 days
#10 posted 06-05-2013 07:16 AM
I knew I’d read a long and interesting article about this a while back, I dug it out and it’s here…
http://forums.shoryuken.com/discussion/67501/how-to-paint-mdf-to-a-mirror-finish-worklog
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
404 - Not Found
2544 posts in 2933 days
#11 posted 06-05-2013 08:49 AM
If the finish resembles that of a high gloss slab door, it will have a plastic film coating on it, not paint or lacquer. I’ve done a few mdf projects where I’ve gloss lacquered over the paint and they came out with that wet look.
poopiekat
#12 posted 06-05-2013 11:54 AM
KnickKnack: Man you hit it!! Yesss, this is exactly the tutorial I was hoping to see. His finished product is absolutely stunning! I’m anxious now to get started on a few MDF projects, once I get some other obligations out of the way.
I’m grateful that you took the time to find this article, I see it was posted four years ago. Your efforts are appreciated beyond words, and I hope others find it helpful too.
Thanks to everyone who contributed!
View Airspeed's profile
Airspeed
445 posts in 1866 days
#13 posted 06-05-2013 03:03 PM
After baking these in a home made oven for 24 hours to get the MDF stable I sprayed them with sandable primer, sanded smooth until I get it to 600, then I sprayed them with 2k urethane, wet sanded them to 2000 and buffed them with compound and finally polish. They are super glossy.
-- http://smg.photobucket.com/albums/v655/aaronhero/
View Mainiac Matt 's profile
Mainiac Matt
7932 posts in 2292 days
#14 posted 06-05-2013 03:25 PM
Airspeed, your speakers look AWESOME!!
I know very little about high end painting…. but I’ve been able to scrounge some MDO left over from projects at work in the past, and it is great stuff….. very flat, smooth and stable. The paper-like surface is tough… almost like a phenolic impregnated skin.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
poopiekat
#15 posted 06-05-2013 04:07 PM
Airspeed: Wow, that is excellent workmanship, for MDF this is astoundingly high craftsmanship!
And that finish…just like the stock I bought that I referred to in the original post. I now know that this type of finish is achievable in the home shop! Though my next MDF project will be rectilinear in nature, nobody can argue with the flowing lines of your speaker project. That surface is just like glass. Thanks for sharing the pic with us!
