PM3520B Additional Weight
« back to Woodturning forum
Forum topic by Big Ben posted 06-04-2013 12:09 PM 2343 views 0 times favorited 12 replies Add to Favorites Watch
View Big Ben's profile
Big Ben
87 posts in 2915 days
06-04-2013 12:09 PM
I bought a PM3520B over the weekend. With my previous lathe (Nova 3000) I added weight to the bottom, I am wondering if that is needed for PM3520B. I do want to on occasion outboard large items but mostly do bowls and hollow forms.
12 replies so far
View Kreegan's profile
Kreegan
1452 posts in 2171 days
#1 posted 06-04-2013 12:28 PM
I believe the 3520B is over 800 lbs, so unless you’re planning on turning really large and out of balance pieces, you’re likely good. If it’s an option, bolting it to the floor would still be a good idea.
View Wildwood's profile
Wildwood
2322 posts in 2159 days
#2 posted 06-04-2013 03:59 PM
They show a couple different style shelves in the owner’s manual that would let you add weight too. I have one like figure 11 in the manual for my Jet 1642 loaded with concrete blocks. It’s a chip and junk collector. My lathe not bolted to the floor will rock a little with out of balance pieces if speed too high, dialing back speed solves that problem. Your lathe lot heavier than mine, so whether you add weight or not will end up dialing speed back at times.
http://content.powermatic.com/manuals/1352001_man.pdf
Not to worry try it without a shelf for awhile can always add weight later.
Good luck with your new lathe!
-- Bill
View mpax356's profile
mpax356
72 posts in 2517 days
#3 posted 06-05-2013 09:00 PM
I don’t know any turners that have one who felt the need to add weight. Try it for a while before you bother. I did add a compartment box, but not to add ballast but for some more storage room. It is heavy but certainly not 800#. Ship weight is 682.
-- MPax, Atlanta
View TJinNC's profile
TJinNC
9 posts in 2359 days
#4 posted 06-07-2013 02:45 PM
The physics of adding more weight is always better, especially if you plan on turning out of round or even very large blanks. I put a couple hundred pounds of sand in a tray under my 3520.
Couple other suggestions: Ditch the adjustable feet. If you need it elevated, shim it with hardwood/steel and shim it correctly to be sure you remove as much residual stress in the lathe bed as possible. This will help prevent vibrations caused by poor overall weight distribution to the feet of the lathe.
Do this by lifting up the tailstock side leg from a central position front/back at the extreme right end of the lathe, and notice which support pad becomes ‘loose’ first. Add/remove shims till the feet have equal loading front/back on the tailstock side. The headstock side will be automatically taken care of by doing this properly on the tailstock (lighter) side. Have fun!
Big Ben
#5 posted 06-07-2013 05:48 PM
TJinNC I plan on getting rid of the levelers and bolting 6×6 post to the legs to get more height to suite me, I am 6’7”.
Does it matter if I have the weight resting on the posts or should it be on the self?
TJinNC
#6 posted 06-08-2013 01:18 AM
Hey Ben…I must be at the other extreme…I’d like to take about 2 inches off my 3520 to make it suit me! :-D
Nothing wrong with applying the weight to the integral supports for a shelf to carry the weight, and the dampening effect of the extra mass will be better if placed on the lathe directly, as opposed to the supports you plan to bolt to. Also, I like having the area clear under the lathe for my feet…and I suspect you’ll need it even more so.
If I understand correct, you’ll have two 6×6 sections to span each leg’s 2 pads, each about 24” or so long. Sounds like a plan. Still be sure to shim out the underside of the 6×6 section on the tailstock end like I talked about above. It will smooth things out and give less chance of ever cracking a bed casting (never heard of it first hand, only word of mouth) due to fatique stress.
6’7”...man, you needed the 4224! Nah, you’re gonna be very happy with the 3520, no better value in a full size lathe out there in my opinion.
Wildwood
#7 posted 06-08-2013 09:50 AM
View PASs's profile
PASs
595 posts in 3123 days
#8 posted 10-27-2013 04:43 PM
Ben,
I’ve had my 3520 about 18 months.
Even with a 50” and 18” installed I’ve had issues when turning larger (100 lb plus) unbalanced pieces, specially when doing the initial rounding.
I’m still running on the original feet but am thinking about setting anchor/leveling bolts into the garage floor.
-- Pete, "It isn't broken, you just aren't using it right."
View mantwi's profile
mantwi
312 posts in 1921 days
#9 posted 10-27-2013 06:07 PM
The adjustable feet are the weak link in many otherwise robust machines. Picture a 345lb linebacker wearing ballet shoes and running on his toes, he would be a little tippy. The mass needs a good solid point of contact to dampen vibration. Sitting above on four thin bolts isn’t giving it that solid base. As suggested you should either bolt it down or at least use something other than the supplied wimpy adjustable feet with sturdier material.
By the way congratulations on purchasing a great lathe.
View rum's profile
rum
148 posts in 2611 days
#10 posted 10-28-2013 04:55 PM
I’m in the “more weight is better” camp. I ran my 3520 for about 8-9 months without any and then added a cabinet and put another ~200lbs of gravel into the bottom of the cabinet. Mostly I put the cabinet in because I wanted the storage (and yes it does catch some chips, but not to bad, I made the face of the drawers about flush with the side of the lathe bed and left plenty of room to push shavings out between the lathe bed and the cabinet itself). Anyway with the extra weight there was a noticeable reduction in vibration with even medium sized pieces (kind of like from small shimmer to no shimmer) and larger pieces I could definitely spin up a bit faster.
Did the lathe work just fine for pretty much everything without it? Well yes.. :D but it does imho work even better with it.
View bigblockyeti's profile
bigblockyeti
5138 posts in 1745 days
#11 posted 10-28-2013 05:05 PM
I bolted my little (modified) craftsman to the floor and it made a world of difference.
View PASs's profile
PASs
#12 posted 10-28-2013 06:11 PM
Bigblock,
I had two Craftsman tube-bed lathes before the Powermatic.
Was going to join them end-to-end for longer turning capacity.
Just curious what mod’s you made to yours.
