Ripping thick maple - she got 'er done!
Forum topic by Sandra posted 06-04-2013 01:19 AM 1896 views 1 time favorited 43 replies Add to Favorites Watch
View Sandra's profile
Sandra
7207 posts in 2225 days
06-04-2013 01:19 AM
Topic tags/keywords: table saw blade maple question
Next step in my workbench build is ripping maple for my benchtop. Some of the pieces are close to 3” thick.
I have a Bosch 4000 10” contractor saw with the 40-tooth carbide tip blade that came with it. The only other TS blade I have is for plywood and plastics. (can’t remember how many teeth, but at least 80 with shallow gullets.)
Now I’m fairly certain my 40 tooth blade is not up to ripping anything that thick. In fact, I’m worried about whether the saw will be up to it. What type of blade would you suggest I try? And any other suggestions about ripping such thick stock??
Thanks -
I ran the boards through the planer today – here’s the nicest pile of shavings I’ve ever seen!
-- No, I don't want to buy the pink hammer.
43 replies so far
19096 posts in 2006 days
#1 posted 06-04-2013 01:30 AM
I bet a nice Freud ripping blade would do it. I would say 24 teeth.
#2 posted 06-04-2013 01:32 AM
BTW that’s a nice planer cart. I need to do that.
Sandra
#3 posted 06-04-2013 01:35 AM
Thanks FF. The planer cart has served me well. Hopefully HD will have what I need here in town.
View gfadvm's profile
gfadvm
14940 posts in 2840 days
#4 posted 06-04-2013 01:41 AM
Sandra, I would try a 24 tooth thin kerf rip blade (Diablo from HD is an inexpensive blade that works well for me). If this is still too much for your saw , you may have to rip halfway through, flip, and finish from the other side.
Not sure if you have hard or soft maple. 3” of hard maple will be more than your saw wants in one pass for sure.
13630 posts in 3491 days
#5 posted 06-04-2013 01:41 AM
a couple of ways i can think of sandra
run 1 edge straight on the jointer
and on the band saw rip slightly oversize
and on edge thru the planer again to final width
same with the table saw
but just set it at 1 5/8” heighth
and flipping the wood end over end
cut it twice (once each side)
and do the same with the planer
the main stock needs to be run back across the jointer each time
to give another straight edge
done right you should be able to make a pile of rough cut one side pieces
ready for the planer that way
and do that process all at once
i usually cut even up to 1/8”and watching the grain if it might be wandering some
do the part jointer face down to the planer table
with the top grain going up as it comes into the planer knives not against them
then flipping end over end again
do the original jointer face too just in case
some times the board may have a slight dip here or there
those i just plane and extra 1/32” after i see that problem
and just take the original edge down the other 1/32”
to make them all even
that last pass all are done to the same setting
(even if i have to cheat 1/64” to get them all the same
hope i’m not to confusing here
whoopee on all that saw dust !
View AandCstyle's profile
AandCstyle
3165 posts in 2407 days
#6 posted 06-04-2013 01:43 AM
You could use your band saw for the ripping, if you have one. Oops, David beat me to it. :)
-- Art
View pmayer's profile
pmayer
1029 posts in 3215 days
#7 posted 06-04-2013 01:45 AM
Even with a good 24 tooth ripping blade I think that’s too much maple for that saw. I would do it the same way that David described if you have a decent band saw.
View RonInOhio's profile
RonInOhio
721 posts in 3014 days
#8 posted 06-04-2013 01:45 AM
Cutting it halfway through on one pass and flippping it for the second on the TS sounds like a good suggestion.
And I pretty sure those Diablo 24 T blades are only around 9.99 at HD.
Sandra
#9 posted 06-04-2013 01:47 AM
Thanks David,
Not confused, I think I follow you. It’s hard maple, so you’re right in that I don’t imagine my saw can handle it in one pass. I have the boards jointed on one side so far for use at the TS
Art – I do have a Rikon 10-325 which I’ve only had a few months. My first attempt at resawing was through a 5” wide, 2” thick piece of walnut. It was atrociously slow and a lousy cut to boot. I have to figure out the resawing better before tackling anything else.
Sandra
#10 posted 06-04-2013 01:53 AM
http://www.homedepot.ca/product/freud-10-in-diablo-ripping-blade-24-teeth/973187
Is this the right type of blade?
View Don W's profile
Don W
18970 posts in 2717 days
#11 posted 06-04-2013 01:57 AM
View RussellAP's profile
RussellAP
3104 posts in 2436 days
#12 posted 06-04-2013 01:58 AM
If the pieces are not too long, I’d use my bandsaw. I can tell you my Ridgid 4512 has cut 4” walnut like butter with a frued thin kerf 80t. You just go a little slower and let the blade do the work.
BTW have you ever seen a pile of shavings like that catch fire? Don’t use it for landscaping….just in case you were thinking of it. I speak from experience.
Sandra
#13 posted 06-04-2013 01:59 AM
Don – As if….;)
AandCstyle
#14 posted 06-04-2013 02:01 AM
The issue is likely your BS blade. Get either a Timberwolf from Suffolk Machinery or a Woodslicer from Highland. I use a 3 tpi 1/2” blade most of the time and have resawn 8” oak on a 14” Jet without any problems. HTH
-- Art
Sandra
#15 posted 06-04-2013 02:01 AM
The pieces are 62-66” long. I may get the Freud blade and cut the thinner pieces first, see how I make out. When I get to the thicker pieces, I think I’ll try the suggestion of cutting 1/2 way through.
I guess I can justify the cost of the blade with the fact that the maple was only $1.50 bf
showing 1 through 15 of 43 replies
