HF Inlay kit vs MLCS inlay kit
Forum topic by Scott C. posted 06-03-2013 10:56 PM 932 views 0 times favorited 5 replies Add to Favorites Watch
View Scott C.'s profile
Scott C.
158 posts in 2080 days
06-03-2013 10:56 PM
Broke the Harbor Freight bit on the second pass. Can I expect a stronger bit from the MLCS kit? I think maybe I need to slow down when pushing the router, and possibly pick up a trim router for better control.
-- measure twice, cut once, swear and start over.
5 replies so far
View pintodeluxe's profile (online now)
pintodeluxe
5706 posts in 2842 days
#1 posted 06-03-2013 11:07 PM
I have found it is pretty easy to break the 1/8” bit in those kits. I am using the Whiteside kit now, and it has worked flawlessly on many inlays. It is solid carbide. I go slow, and only rout 3/16” deep.
View knotscott's profile
knotscott
8057 posts in 3404 days
#2 posted 06-04-2013 12:26 AM
I’ve got the Freud inlay set, and break those bits pretty easily too….it’s just the nature of a 1/8” bit.
View gfadvm's profile
gfadvm
14940 posts in 2719 days
#3 posted 06-04-2013 01:46 AM
I use the solid carbide 1/8” spiral bits from Grizzly and haven’t broken one yet. I do take multiple shallow passes (usually 1/8” in harder woods). I did break straight fluted bits regularly.
View kdc68's profile
kdc68
2658 posts in 2305 days
#4 posted 06-04-2013 03:06 AM
Scott...Agreed with above comments….shallow passes are best with such a small diameter bit….solid carbide and/or spiral bits are better suited…a trim router is handy for a lot of tasks like edge forming for example…easy to control….
good luck with your inlays
-- Measure "at least" twice and cut once
View LoydMoore's profile
LoydMoore
105 posts in 1985 days
#5 posted 06-04-2013 04:49 AM
HF bit looks lousy but works. I mostly use my Diablo 1/8 but have not had any problems when using the HF.
-- Loyd, San Angelo, TX http:www.moorewoodenboxes.com
