bare HVLP turbine
Forum topic by Charlie posted 06-03-2013 10:36 PM 1037 views 0 times favorited 7 replies Add to Favorites Watch
View Charlie's profile
Charlie
1100 posts in 2285 days
06-03-2013 10:36 PM
I may have an opportunity to pick up a 6PSI, 65CFM turbine for $10. It’s only the turbine. No hose, no gun, no nothing, and the only thing the guy knows about it is that it powers on and “air comes out the nozzle in the front”.
Appears to be a Campbell Hausfeld HV3000 turbine. My question is, how universal are the hoses? I don’t have an HVLP sprayer… or any other sprayer for that matter, but if I can find pieces and parts, can they be mixed and matched to make a working system?
I mean if I get this for $10 and it works, I could go to HF or something and get a gravity feed gun, but the hose… where would I get the hose? :)
7 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2037 days
#1 posted 06-03-2013 10:47 PM
hose is common, universal, available anywhere that sells the guns.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View NiteWalker's profile
NiteWalker
2737 posts in 2576 days
#2 posted 06-04-2013 10:16 AM
Most turbines use universal fittings, but you won’t be able to use any old hvlp gun on it. It has to be rated for turbine use. I haven’t seen turbine guns that were cheap. Even the cheapest I seen was a bit over $100.
Charlie
#3 posted 06-04-2013 10:31 AM
I thought most of the HVLP “blowers” are turbines. I see “2 stage”, “3 stage”, etc.
NiteWalker
#4 posted 06-04-2013 02:31 PM
They are; a lot of them use the same motor in fact. I know for sure my fuji mini-mite 4 and the apollo 1035 use the same exact 4 stage turbine unit inside.
The issue is the gun. Compressor guns are conversion guns; they are designed to take a higher volume of compressed air (~29-35psi at the gun) and convert it down to the 6-10psi at the gun tip.
The apollo 7500 is the only gun I know of that can be used on a compressor or a turbine. It’s a great gun, I love mine, but it’s not cheap.
View Earlextech's profile
Earlextech
1161 posts in 2690 days
#5 posted 06-04-2013 03:00 PM
I knew a guy that would drive 10 miles out of his way to get gas 3 cents cheaper.
You might save money on the turbine, but you will spend your time trying to assemble a system that you can buy complete for $500 or less and then be spraying tomorrow.
I know a lot of guys that like to assemble and create mechanical things. I’m not one of them, I’m a woodworker. If you are, go for it and enjoy the journey. If I can buy it easily, why would I build one? Good luck.
Charlie
#6 posted 06-04-2013 03:06 PM
Very true. Maybe I’ll see if I can get an Earlex 5500 for father’s day or my birthday. :)
Seems as good a place any any to get started.
Shawn Masterson
1325 posts in 1948 days
#7 posted 06-04-2013 09:16 PM
I would call a paint store and play 20 questions. They would know better.
