Finish for outdoor walnut furniture (covered porch)
Forum topic by yellowtruck75 posted 06-03-2013 04:34 PM 1318 views 0 times favorited 2 replies Add to Favorites Watch
View yellowtruck75's profile
469 posts in 3003 days
06-03-2013 04:34 PM
I got a request from a potential client for a pair if walnut Maloof rockers to be used on a covered porch outside. I need help with a durable finish that will withstand the elements. I use a traditional Maloof finish of poly, tung oil, & BLO, will this work or should I use more of a varnish?
2 replies so far
View Joe Lyddon's profile
Joe Lyddon
10012 posts in 3988 days
#1 posted 06-03-2013 07:41 PM
Good question… I await the answer(s)...
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
View tinnman65's profile
1356 posts in 3350 days
#2 posted 06-03-2013 09:27 PM
I am not a finishing expert but I would guess a marine varnish (oil with UV absorbers added). Linseed oil is susceptible to mildew growth as the mildew feeds on the fatty acids in the oil so don’t use that. If you go with a marine varnish remember the finish will deteriorate over time and will need to be touched up. I would think being under a covered porch it will last much longer than being left out in all the elements. Good luck I hope someone with more knowledge answers you but I thought this would at lest get you heading in the right direction.
-- Paul--- Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep. — Scott Adams
