Two "Which Glue?" questions
Forum topic by Lee Barker posted 06-03-2013 04:07 PM 1087 views 0 times favorited 7 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 3088 days
06-03-2013 04:07 PM
1. Which wood glue dries the clearest?
2. What adhesive will best joint wood to plexiglas (polystyrene)?
Thanks kindly,
7 replies so far
View MrFid's profile
MrFid
888 posts in 2142 days
#1 posted 06-03-2013 04:18 PM
Maybe there are others who will disagree, but to me the answer to both of those questions is CA (cyanoacrylate) glue. Also called Super glue commercially. I use this glue in turning pens, and it dries 100% clear, is very adhesive to wood, and will certainly grip plexiglass. Depends on how porous the wood is that you’re trying to adhere to I guess. Maybe someone knows better than me.
-- Bailey F - Eastern Mass.
View Woodknack's profile
Woodknack
12464 posts in 2617 days
#2 posted 06-03-2013 05:12 PM
Agreed, CA is the clearest glue I’ve used.
View Woodendeavor's profile
Woodendeavor
276 posts in 2844 days
#3 posted 06-03-2013 05:40 PM
What is the application? If you are applying a top to a wooden base, the glass industry uses these adhesive buttons that stick well to finished wood. The are a good look under a clear top from the uniformity of the button
117417 posts in 3814 days
#4 posted 06-03-2013 05:46 PM
White glue dries clear, do a test and see what you think Lee. White glue is what I use when I glue have to glue pieces that have already been finished.
View waho6o9's profile
waho6o9
8539 posts in 2814 days
#5 posted 06-03-2013 06:34 PM
View LakeLover's profile
LakeLover
283 posts in 2177 days
#6 posted 06-03-2013 07:59 PM
Weldbond dries nice and clear.
Plexi IIRC you can use Future Acylic floor finish as a cement.
But do you need a flexable joint with the plexi ? The Lexel maybe a better choice.
View Clint Searl's profile
Clint Searl
1533 posts in 2598 days
#7 posted 06-03-2013 09:29 PM
1. Epoxy
2. Epoxy
