A hole saw in router?
Forum topic by docspencer posted 06-03-2013 10:59 AM 1521 views 0 times favorited 16 replies Add to Favorites Watch
View docspencer's profile
docspencer
354 posts in 1946 days
06-03-2013 10:59 AM
I saw a video where someone glued sandpaper to a hole saw then used a drill press as a kind of drum sander for sanding curves. I don’t have a drill press but is it safe to put the hole saw in a router mounted in a router table?
16 replies so far
View Bill White's profile
Bill White
4932 posts in 3961 days
#1 posted 06-03-2013 11:13 AM
In one word…....NO!
-- bill@magraphics.us
404 - Not Found
2544 posts in 2970 days
#2 posted 06-03-2013 11:23 AM
Even on it’s slow speed a router will be way too fast. Don’t do it.
View Ripthorn's profile
Ripthorn
1458 posts in 2986 days
#3 posted 06-03-2013 11:24 AM
Holy bad idea, Batman! As the others have said, it would be extremely unsafe. Imagine all those sharp teeth pointed up at you spinning at thousands of RPM’s. Also, I doubt they would fit the collet very well if at all, so there would be a lot of risk of it flying out.
docspencer
#4 posted 06-03-2013 11:34 AM
Okay – that one is settled. Thanks guys. Next question – I’m going to make a chip and dip tray: one of those oval shaped ones with a hole for dip on each end. I needed the hole saw/sandpaper to sand the template after I rough cut it out. Any ideas other than hand sanding????
404 - Not Found
#5 posted 06-03-2013 11:45 AM
I recommend using 3/8” mdf for the template and use a jigsaw with a fine curve cutting blade. If you have a steady hand it won’t need much cleaning up. Do the rough sanding with p60, clean up the whole thing with p120. It won’t take long.
View crank49's profile
crank49
4030 posts in 2972 days
#6 posted 06-03-2013 12:09 PM
Only if you have a death wish.
View shampeon's profile
shampeon
1775 posts in 2184 days
#7 posted 06-03-2013 02:49 PM
20,000 RPM is no joke. The only thing that goes into a router is a router bit. Even then, be afraid.
View PurpLev's profile
PurpLev
8535 posts in 3649 days
#8 posted 06-03-2013 02:54 PM
just use sandpaper with a backer block (MDF/plywood/cutoff) suited to fit your intended area to be sanded (large and flat or narrow and round…) and hand sand it.
docspencer
#9 posted 06-04-2013 02:16 AM
Yeah, that’s pretty much what I thought. Thanks guys. Maybe I can talk my wife into letting me buy a drill press :)
View bondogaposis's profile
bondogaposis
4733 posts in 2352 days
#10 posted 06-04-2013 03:26 AM
I’m glad you came to your senses. Man, a hole saw in router? There’s no happy ending there.
-- Bondo Gaposis
View blackcherry's profile
blackcherry
3338 posts in 3824 days
#11 posted 06-04-2013 03:30 AM
That one ride you want no part of and believe me if you tried it would look like some angry beavers went to town.
View ajosephg's profile
ajosephg
1880 posts in 3562 days
#12 posted 06-04-2013 12:55 PM
View helluvawreck's profile
helluvawreck
31105 posts in 2867 days
#13 posted 06-04-2013 01:14 PM
Tools like you are referring to will almost always have a warning stamped on telling about the maximum RPM that it can be run. I’m positive that no tool like a hole saw is rated to be run on a router. It can fly apart and instantaneously kill the operator or anyone else in the room.
helluvawreck aka Charles
View Tennessee's profile
Tennessee
2873 posts in 2515 days
#14 posted 06-04-2013 01:21 PM
With the proper coupon you can get one of these from HF for $89.
http://www.harborfreight.com/14-oscillating-spindle-sander-69257.html
I own two of them, the older style that is a copy of the Triton that sells at Klingspor for $169.99. I abuse the heck out of them, and they just keep going. One problem, they put out enough RF to kill my radio signal in my shop when running. Other than that, on their second year, and still sanding away!
Unfortunately, they are changing the model to look like the one in the URL I listed. Unknown if any other changes occurred besides tabletop and a little body change.
View BBF's profile
BBF
143 posts in 1840 days
#15 posted 06-04-2013 01:32 PM
KKKKKKKAAAAAAAABBBBBBBBBBOOOOOOOOOOOOOOOOOOOMMMMMMMMMMMMMM
-- I've never been disappointed buying quality but I have been disappointed buying good enough.
