Magnetic dial indicator holder for bandsaw fence
Forum topic by OhioMike posted 06-03-2013 06:54 AM 4194 views 2 times favorited 4 replies Add to Favorites Watch
View OhioMike's profile
OhioMike
79 posts in 2065 days
06-03-2013 06:54 AM
Topic tags/keywords: bandsaw band saw dial indicator veneer fence micro adjust magnet magnetic micro-adjust tablesaw veneering resource jig
I finally got around to building an easy-to use dial indicator holder for my bandsaw fence. It’s useful when I need to change the thickness of the veneer I’m cutting.
I started with a scrap of oak about 1.5 inches thick with one surface absolutely flat. I cut slots in it as shown.
And I drilled two 1/4” holes at the drill press.
Four shallow holes on the (absolutely flat) underside accept 1/2” x 1/8” magnets that are epoxied in place. They are about 1/64” below the surface of the wood.
A coat of shellac protects it.
This scrap of 1/4” thick plastic provided material for a lever.
An inexpensive Grizzly dial indicator complete the project. Here is the plastic lever in action
I hope you enjoyed it.
Mike
View MrRon's profile
MrRon
4627 posts in 3146 days
#1 posted 06-03-2013 03:59 PM
The plastic leveris a great idea.
View Planeman40's profile
Planeman40
1100 posts in 2663 days
#2 posted 06-03-2013 04:31 PM
If you can work to the tolerances of a dial indicator with a bandsaw, my hat is off to you and I nominate you for “Bandsaw Genius of the World”!
Planeman
OhioMike
#3 posted 06-03-2013 05:26 PM
Gee, I thought I was measuring my veneer the old tried-and-true way by using thousandths.
You know:
1/16” = .062
3/32” = .093
1/8” = .125
and so on…...
It’s so much easier to use a dial indicator and calipers than a ruler!
Mike
Planeman40
#4 posted 06-03-2013 06:17 PM
I guess you can do that. I would just put a small ruler against the blade and the fence. But since you are slicing veneers, I can see where your method would be valid. But I don’t think I could hold tolerances within a couple of thousandths on a bandsaw. Not even with a table saw. Your nomination will be in the mail shortly. :)
Planeman
