Question about bench vises
Forum topic by Trueblue posted 06-03-2013 06:53 AM 1554 views 0 times favorited 5 replies Add to Favorites Watch
View Trueblue's profile
Trueblue
1 post in 1729 days
06-03-2013 06:53 AM
Topic tags/keywords: vise vises bench vise front vise woodworking vise
My husband and I are wanting to purchase a high quality bench vise for his woodworking. We are wondering what the difference between the Quick Release bench vise:
http://www.leevalley.com/en/wood/page.aspx?p=49980&cat=1,41659&pb=1#pb
and the Front vise:
http://www.leevalley.com/en/Wood/page.aspx?p=31137&cat=1,41659,41661&ap=1
The front vise is way cheaper, as you can see. What would be the purpose of getting the more expensive one with the steel jaws?
5 replies so far
View waho6o9's profile
waho6o9
8100 posts in 2486 days
#1 posted 06-03-2013 12:38 PM
http://www.highlandwoodworking.com/search.aspx?find=pattern+makers+vise
A high quality vise is a pattern makers vise IMHO. It can pivot to 90 degrees and
is very versatile as it can rotate 360 degrees as well.
It’s worth a look. Good luck.
The one with the steel jaws has a “dog” in the center so you can line it up with the dog
holes in your work bench and it has a face.
The other one you must make a face to use with your work bench.
If you narrowed it down to those two I’d purchase the one with the dog.
Welcome to LJ’s Trueblue!
View OhioMike's profile
OhioMike
79 posts in 2072 days
#2 posted 06-03-2013 12:45 PM
One major difference is that the more expensive vise has a quick release. Instead of turn, turn, turn, turn, turning the handle to open the jaws, you just release the screw mechanism and pull the front jaw open.
Mike
View redSLED's profile
redSLED
790 posts in 1802 days
#3 posted 06-03-2013 12:58 PM
If you anticipate vising (is that a word?) various thicknesses of wood daily/very frequently then you may prefer the quick release option. Those vises also don’t require you to make jaw faces whereas with the cheaper front vise you will have to, although it seems most wood workers make their own wooden jaw faces regardless of vise style.
View Bernie's profile
Bernie
422 posts in 2746 days
#4 posted 06-03-2013 03:38 PM
The differences have been explained, I think you will still want to add wood to your face plates so as to not dent the wood. Consider what kind of bench this vise is going be attached too… does it have dog holes? If so, you may want to take advantage of them and get what you call the front vise. It’s exciting to be setting up a shop but it can be expensive, especially if you buy the wrong tool.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
View Kreegan's profile
Kreegan
1452 posts in 2056 days
#5 posted 06-03-2013 04:58 PM
If you’re doing an operation like hand cutting dovetails or tenons, a quick release vise is a godsend because of how much faster and easier you can change the orientation and position of the wood while you work on it. With both types, you’ll most likely want wooden jaws, possibly covered with leather or suede for grip. It really depends on the uses you see yourself putting the vise to. Is your husband more of a hand or power tool woodworker?
