Broken Bandsaw Tensioner
Forum topic by MacsShop posted 06-03-2013 06:53 AM 3548 views 1 time favorited 29 replies Add to Favorites Watch
View MacsShop's profile
MacsShop
12 posts in 1695 days
06-03-2013 06:53 AM
Topic tags/keywords: question bandsaw
So i got this new bandsaw not too long ago and a buddy of mine was using it but did not make relief cuts and he put to much strain on the blade then all he heard was a ‘pop’ and the blade lost tension. I tried re tensioning it but when i turn the nob it seems like nothing is happening. It looks like the spring in the back lost tension or something, i dont know. Some help would be nice, i included pictures of my band saw.
Oh and first post, booya
-- Mac, Ottawa
29 replies so far
View OhioMike's profile
OhioMike
79 posts in 2038 days
#1 posted 06-03-2013 10:46 AM
Here is what mine looked like when it broke.
Your mechanism may not be broken in the exact same place, you’ll need to remove it to get a look.
If King doesn’t sell the part, I’ll bet Grizzly has one that fits.
Mike
View REO's profile
REO
927 posts in 1949 days
#2 posted 06-03-2013 02:58 PM
did the nut strip out? this type of adjuster is notorious for that. I have fixed several by making a new nut that is thicker and making a new screw that has a higher percent thread.
MacsShop
#3 posted 06-04-2013 01:30 PM
The nut and screw are perfectly intact. Mike I took off the top wheel and nothing seems to be broken. I think it’s just me and the lack of knowledge I have about this tool haha. I still won’t tension.
-- Mac, Ottawa
OhioMike
#4 posted 06-04-2013 04:24 PM
With the wheel off you can now remove the sheet metal guard and the adjuster should lift straight up. I’ll bet REO is correct and you’ll find stripped threads on either the rod or the nut.
Mike
View REO's profile
REO
#5 posted 06-04-2013 04:30 PM
have you removed the tension screw and evaluated the thread. The first picture shows a worn thread on the adjuster.
View Cole Tallerman's profile
Cole Tallerman
392 posts in 2060 days
#6 posted 06-04-2013 05:13 PM
If you want to replace it, any mechanism from carter, grizzly, powermatic, jet 14” bandsaws will fit. This will also give you quick release.
MacsShop
#7 posted 06-05-2013 04:36 PM
Nothing seems to be striped
-- Mac, Ottawa
OhioMike
#8 posted 06-05-2013 04:55 PM
Unscrew the tensioning knob. Unscrew it all the way and take it out and inspect it. Look at the nut it screws into as well.
Pics of the tensioning knob (and its shaft) as well as pics of the nut would be great if you can.
Mike
MrUnix
6200 posts in 2074 days
#9 posted 06-05-2013 07:03 PM
What Mike said. The threads on the wheel shaft that you keep showing have nothing to do with tensioning. Below is a picture of all the parts to the tensioning assembly. Pull yours off completely so you can remove the tensioning rod and knob to inspect. Check the threads on the rod to make sure they are not stripped. Do the same with the nut (less likely but still a possibility). Also make sure your spring is not broken.
PS: The parts shown above are for a Delta BS.. Yours is a clone of the Delta, so the parts are basically identical.
MacsShop
#10 posted 06-05-2013 11:41 PM
The thread looks good
-- Mac, Ottawa
OhioMike
#11 posted 06-06-2013 11:56 AM
Are you certain the threads are good? From the picture, it appears many of the threads have lost their sharpness.
1> Try to push the nut up the shaft and see if it will jump over the threads. Push the nut hard and wiggle it too. Were you able to make it jump a thread? If not, advance the nut a couple of turns and try again. Keep going until you’ve tested the threads all the way up the shaft.
Mike
MacsShop
#12 posted 06-07-2013 12:29 AM
I put the nut in my vice and pushed and wiggled as hard as i could and they did not jump
-- Mac, Ottawa
View jumbojack's profile
jumbojack
1673 posts in 2499 days
#13 posted 06-07-2013 01:00 AM
From here it looks like the nut is outside the tensioner. last time it was detensioned it went too far out. The nut actually compresses the spring, so it must ride inside the housing. hth
View REO's profile
REO
#14 posted 06-07-2013 03:17 AM
jumbojack has a point. it is possible that the nut is spinning outside the housing.
MacsShop
#15 posted 06-09-2013 10:55 PM
i put it all back together and made sure the nut was in the housing. when tightening it the spring doesn’t compress. any clue on why that is happening?
-- Mac, Ottawa
showing 1 through 15 of 29 replies
