blackened router bit
Forum topic by toolie posted 06-02-2013 10:58 PM 1361 views 0 times favorited 7 replies Add to Favorites Watch
View toolie's profile
toolie
2148 posts in 2829 days
06-02-2013 10:58 PM
i had to route a slot in a dril press table which was 3/4” plywood topped with 1/4” MDF. this is what the bit looked like after the routing:
when i routed a wider slot in the underside of the 3/4” plywood base with a larger router bit,it didn’t blacken, so i’m guessing it’s somehow related to the MDF. any thoughts and suggestions for cleaning the subject bit?
7 replies so far
View JustJoe's profile
JustJoe
1554 posts in 2239 days
#1 posted 06-02-2013 11:02 PM
a few things you can try – maybe slow down the router speed a tad or take multiple passes instead of going full-depth or use a dado-bit instead of a straight bit.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View gfadvm's profile
gfadvm
14940 posts in 2891 days
#2 posted 06-03-2013 01:32 AM
As far as cleaning that bit, I soak mine overnight in bug and tar remover from the auto parts store (even my bearing bits). Works great. I put about 1” of the remover in a small jar and replenish as needed. I clean all my bits every time I use them and have never changed out my cleaning solution.
You could also soak non-bearing bits in Simple Green like I do my sawblades.
View jusfine's profile
jusfine
2422 posts in 3127 days
#3 posted 06-03-2013 01:38 AM
Did you pre-drill a hole or use that bit to plunge through? I have had the same thing happen when plunging that style of bit.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View Woodknack's profile
Woodknack
12431 posts in 2581 days
#4 posted 06-03-2013 05:24 PM
I had an old bit worse than that, soaked it in citrus degreaser for about a minute and wiped the black off.
View DS's profile
DS
3033 posts in 2621 days
#5 posted 06-03-2013 09:20 PM
Slow down RPM and/or speed up the feed speed.
In other words, you need a higher chip load to carry off the excess heat.
The larger bit you used on the backside had a higher chip load and didn’t burn.
View NiteWalker's profile
NiteWalker
2738 posts in 2778 days
#6 posted 06-04-2013 10:20 AM
With MDF you want to take shallow passes, don’t move the router too slow, and have good dust collection. As said, those mdf dust particles heat up and char your bits.
I use rockler’s blade a bit cleaner. Smells like oranges, not harmful to skin really and lasts a long time. I’ve been using the same bottle for 6+years. I use it at full strength and just pour the used cleaner back into the bottle.
toolie
#7 posted 06-05-2013 02:33 AM
seems the lack of dust collection on the mdf was probably a significant contributing factor. so that’s item one to address with a good bit cleaner being item 2.
