Tippe or Tippy Top
« back to Woodturning forum
Forum topic by Wildwood posted 06-01-2013 08:53 PM 7385 views 0 times favorited 10 replies Add to Favorites Watch
View Wildwood's profile
Wildwood
2449 posts in 2309 days
06-01-2013 08:53 PM
I finally turned a tippy top that works. Several years ago learned about them from another message board. Well never had a tippy top flip over like in the video until yesterday.
Had three line drawings that cannot post, not sure why but tired of trying. What brought me success is using millimeters vice inches shown in one of my line drawings also a line drawing from original patent written in German. That patent drawing made me understand cannot have a fat bottom.
Left my stem long and made shorter with my belt/disk sander until got top to flip. While not perfect it works!
https://www.youtube.com/watch?v=vsCkRODdK-E
-- Bill
10 replies so far
Wildwood
#1 posted 06-01-2013 09:00 PM
As you can see my ¼” dowel stem not perfectly straight. Next one will be straight and have some finish.
-- Bill
View Woodknack's profile
Woodknack
12399 posts in 2554 days
#2 posted 06-04-2013 04:17 AM
I’ve been wanting to try one of these. Is this the line drawing?
Wildwood
#3 posted 06-04-2013 10:42 AM
-- Bill
Wildwood
#4 posted 06-04-2013 10:54 AM
The second picture also found in one of those German patent documents is the one that help me the most. I have made several shown in your pictures also from German patent and they never tipped.
I copied 1st picture several years ago, and thought drilling and adding a dowel too much work. So made many like ones shown in you post they got close to tipping. So cleaning out a folder last week found drawing and started to make them again, third one was a charm.
Folks have bought wood balls from hobby stores and found that easier making them that way. Couple of articles at woodturning-on-line. http://www.woodturned.co.uk/html/tippy_tops.html
-- Bill
View Jim Jakosh's profile
Jim Jakosh
21530 posts in 3280 days
#5 posted 05-01-2017 12:11 AM
I made one before and it tried to flip but never did. I just turned one tonight and it spins but does not flip. I made it 3” in diameter and turned with my sphere jig to make sure the ball was perfect. the pin is 5/8”. I know the center of mass has to be below the center of the ball and mine passed the test where you put it anywhere on it side and it should flip the the pin is vertical. I think I might need more material out of the center but can’t do it now that it is off the lathe. I may try to cut off the spindle a little and then bore 4 holes in it to remove mass if that does not work. I use like the way yours works using the wooden ball.
Cheers, Jim
ps. I just reworked the two tops I made and the small one now flips. I cut the spindle down and made the end convex and it flip as it spins slower. The length that it sticks out is .192 x its diameter.
I tried that on the 3” one and even cut out a lot of material with 8 – 3/4” holes all around the stem and it still will not flip The key must be to get the center of mass as low as you can.
Jim
View Hockey's profile
Hockey
145 posts in 587 days
#6 posted 05-01-2017 02:14 PM
I’ve been interested in making tops. Thanks for posting this thread, Wildwood. Tried to watch your video; but, my computer said it was blocked in my country.
View mahdee's profile
mahdee
4006 posts in 1942 days
#7 posted 05-01-2017 05:27 PM
Mine says the same thing:
This video contains content from Warner Chappell, who has blocked it in your country on copyright grounds.
-- earthartandfoods.com
View Tim's profile
Tim
3812 posts in 2136 days
#8 posted 05-01-2017 06:12 PM
Here’s a video that works on how to make one and one explaining how they work.
https://www.youtube.com/watch?v=khpT-ad0TCA
https://www.youtube.com/watch?v=Kwihc4kbNVA
I remember having a plastic version of one of these when I was a kid and it flipped over a lot quicker than the one in this video. I’ve been wanting another, even considering buying one.
Jim Jakosh
#9 posted 05-04-2017 12:47 AM
I just found out some real valuable information in the following video. The one big thing that makes them work is the bottom curve has to be flatter than the sides- not a perfect sphere like I made. The hollowing is better if you take some off the inside of the sides- not a straight hole and the stem should be about 1/2” long and flat to concave on the end- not pointed or convex.
cheers, Jim
https://www.youtube.com/watch?v=XUa3g4p1DY0
Wildwood
#10 posted 05-04-2017 12:27 PM
Found cannot view video linked in my post for same reason, but did enjoy Rick Turns video. For those folks that think turning tippe top is for the simple minded check out the Physics 210 article. Who knew!
http://large.stanford.edu/courses/2007/ph210/pan1/
Turning different style tops more for fun of turning and amusement it brings for those that play with them. Hope after watching Rick Turns video you will give it a shot. Think have turned many different style top seen on Google Images but none as challenging as a tippe top.
https://www.google.com/search?site=&tbm=isch&source=hp&biw=1280&bih=642&q=tippy+tops&oq=tippy+tops&gs_l=img.3...110.2600.0.3190.9.8.0.1.1.0.425.1151.0j6j4-1.7.0....0...1ac.1.64.img..1.7.1140...0.s8bdJhmJ970#tbm=isch&q=wood+turned+tippy+tops&imgrc=_&spf=509
Just pick a style top you like and go for it!
-- Bill
