Is this Frued blade kerf too small for my riving knife?
Forum topic by Jason978 posted 05-31-2013 08:51 PM 1403 views 0 times favorited 8 replies Add to Favorites Watch
View Jason978's profile
Jason978
10 posts in 1862 days
05-31-2013 08:51 PM
hi,
I have the porter cable table saw, the big one.
the riving knife is .09” thick. The blade I bought (frued 50T industrial) has a .091” kerf. Is this too close to the riving knife size to be safe?
thanks,
8 replies so far
View kdc68's profile
kdc68
2658 posts in 2301 days
#1 posted 05-31-2013 09:05 PM
To give you a perspective…a piece of ordinary copy paper is .004. IMO it is too close. I would try a blade that is .098….which is still considered thin kerf..
-- Measure "at least" twice and cut once
View knotscott's profile
knotscott
8056 posts in 3400 days
#2 posted 05-31-2013 10:08 PM
It is close, but there’s going to be some run-out from the saw’s arbor and from the blade itself that should give you some more clearance. Also, the front of the riving knife should be tapered a bit which should help it enter the kerf opening. If everything is aligned really well, it could be ok. You can always give it a try and see how it goes, but be ready to shut it down if things bind.
Jason978
#3 posted 06-01-2013 12:04 AM
if the total runout from the blade /arbor is .002, does that mean that the actual kerf is .091 +.002?
kdc68
#4 posted 06-01-2013 12:16 AM
I will assume yes…
The more clearance with that .090 knife and .091 blade that you can get… the better
I suppose, with calipers, you could measure the kerf of a partially cut board.
View HorizontalMike's profile
HorizontalMike
7758 posts in 2938 days
#5 posted 06-01-2013 01:50 AM
My riving knife is 0.098in and it calls for a blade kerf of 0.102—0.126in. That is a minimum difference of 0.004in to 0.128in difference. In other words, if the riving knife is too close to the size of the blade kerf then you could get some serious (read dangerous) pinching behind the cut. It all depends on the wood and its characteristics (reaction wood, too moist, etc.).
Jason978
#6 posted 06-01-2013 05:34 PM
i think ill try a new blade, better safe than sorry.
kdc68
#7 posted 06-01-2013 05:42 PM
v
v
A blade that is good bang for the buck are the Diablo’s…If you have a Home Depot near you…..They are .098 in kerf…
My riving knife is .090 and I use the Diablo’s with no issues
View NiteWalker's profile
NiteWalker
2737 posts in 2601 days
#8 posted 06-01-2013 05:48 PM
Properly aligned, you should be ok.
Before I got my saw with a riving knife I used a shopmade splitter that was the exact size of the kerf. No issues.
